Author Topic: Guess the horsepower game 6.20.20 # 1  (Read 14135 times)
WerbyFord
Re: Guess the horsepower game 6.20.20 # 1
« Reply #30 on: July 18, 2020, 03:47:30 PM »
Totally agree on the split pattern cam.
I tried every factory FE setup I could in the Gonkulator - they all like a split pettern, usually 6 degrees, give or take a couple.
I think the 428CJ with a 14 degree split was a bit too much, but its better than straight pattern.
I pulled this airflow data off the TFS website.
Is this pretty accurate or is there more realistic data?
This shows Ex/In flow about 75%, which is better than most FoMoCo stuff.
Airflow Results
PowerPort 175
Lift Value Intake Flow CFM Exhaust Flow CFM
.100" 72 63
.200" 151 117 = 77%
.300" 238 171 = 72%
.400" 284 219 = 77%
.500" 317 239 = 75%
.600" 332 245 = 76%
.700" 338 249
Tests conducted at 28" of water (pressure).
Bore size: 4.250"; exhaust with 2" pipe.
https://static.trickflow.com/global/images/chartsguides/t/tfs-56417001-c00_pv.pdf
Brent's values from Stan Weiss site for comparison:
4.155 bore, no pipe: (pretty close to TFS numbers except exhausts about 10% lower)
.100"   96   66 = 69%
.200" 159 120 = 75%
.300" 233 164 = 70%
.400" 283 197 = 70%
.500" 317 215 = 68%
.600" 333 220 = 66%
« Last Edit: July 18, 2020, 08:14:34 PM by WerbyFord »
« Reply #31 on: July 18, 2020, 03:51:03 PM »
Werb, check Stan Weiss' site.  I gave him actual TFS flow numbers a year or so ago.
SMA390
« Reply #32 on: July 24, 2020, 08:40:04 AM »
So who was closest on this one ?
« Reply #33 on: July 24, 2020, 09:09:59 AM »
Looks like Greg Williams.
Text me, Greg!
Gregwill16
« Reply #34 on: July 24, 2020, 04:19:24 PM »
Yay!  ;D
427HISS
« Reply #35 on: July 24, 2020, 04:39:37 PM »
What is split duration, rather than 250-250, is it something like 250-260 ?
« Last Edit: August 07, 2020, 07:16:38 PM by 427HISS »
