Author Topic: Anybody see the FE build on Powernatuon?  (Read 8997 times)
KsHighboy
« on: May 24, 2020, 03:01:43 PM »
I know these guys aren't the legends of FE's like Brent , Barry, Blair  and Jay but nice to see them doing an FE. I know sometimes they short the FE  and don't give it much credit but at least they did one.
Re: Anybody see the FE build on Powernatuon?
« Reply #1 on: May 24, 2020, 03:16:10 PM »
They've actually done two in recent times.  The old junkyard 390 and then the 445.  Pat Topolinski hit me up on Instagram to compare some notes on the 445 as I use a lot of TFS heads.   He's a super nice guy.
Gregwill16
« Reply #2 on: May 24, 2020, 03:57:01 PM »
I actually sold them the 390 block they used for the patina'd FE as they call it. Pat's partner Mike Galley sent me the dyno sheet with some impressive numbers.
chilly460
« Reply #3 on: May 24, 2020, 06:13:17 PM »
Funny you mention as I just finished watching it a couple minutes ago.   Pretty similar to some recent builds here, but they used a pretty big hydraulic roller, wonder if the valvetrain stayed stable.  Happy to see a fairly nice FE build without a bunch of poorly matched parts, and also first build I’ve seen with the TFS intake
KsHighboy
« Reply #4 on: May 24, 2020, 07:04:32 PM »
Yeah, I liked that they used TFS heads and intake. I dont know if it was just the camera angle but it seemed like the angle was a mismatch from intake to head mating surface.
The TFS heads seem to be a good out of the box head from looking at Brents builds. Would love to see what they would do on a 390  with  a low rpm hydraulic roller build like what Blair did without the stroker kit.
« Reply #5 on: May 24, 2020, 07:09:07 PM »
How low?
I’ve done a 390 with them but it peaked at 6.  540 hp.
KsHighboy
« Reply #6 on: May 24, 2020, 07:14:36 PM »
I'm thinking of a cam that peaks in torque at 3500 to 3800. If it revs to 5500 rpm and is done thats fine.
« Reply #7 on: May 24, 2020, 07:41:34 PM »
It's normally around a 1500-1700 rpm split between peak torque and horsepower.  I still think you could make 425-440 hp with a real short cam.
I did a 482 with a BBM block, unported BBM heads, and a Performer RPM intake that made over 620 lb-ft of torque.  It had 590 lb-ft available at 2500 and made 540 hp.  I'd love to see what something like that would do with the TFS heads.
« Last Edit: May 24, 2020, 07:44:33 PM by blykins »
KsHighboy
« Reply #8 on: May 24, 2020, 07:57:46 PM »
So with the hp being around 425-440, what kind of torque would we see?
« Reply #9 on: May 25, 2020, 05:04:54 AM »
I guess is that it would push 500, maybe a hair higher.
KsHighboy
« Reply #10 on: May 25, 2020, 04:50:07 PM »
If it hit 500ft lb that would suit me fine.
« Reply #11 on: May 25, 2020, 04:59:50 PM »
This one made 515 lbft.
http://fepower.net/simplemachinesforum/index.php?topic=6468.0
I’d pull some cam out to give better low end manners.  I think the torque would stay close.
« Reply #12 on: May 26, 2020, 12:59:23 AM »
I just finished watching that video. Pretty decent power numbers. Also interesting crack in that block, guess it froze but usually they are bulged out when that happens.
https://www.youtube.com/watch?v=iLxMVfnvLvU
« Reply #13 on: May 26, 2020, 05:42:27 AM »
It was a pretty lazy cam.  Big duration, but lazy lobes.
KsHighboy
« Reply #14 on: May 26, 2020, 09:48:08 PM »
Thanks Brent! I'm still learning how a hydraulic roller acts compared to a flat tappet.  When I read the specs of a flat tappet I have general idea of the range of power and size.  I'm kinda lost on rollers as I've never been around one or heard one in an FE to get a idea. Dont really know how mild one is or how streetable it is by looking at the specs.
