Author Topic: Clutch Linkage  (Read 16936 times)
Re: Clutch Linkage
« Reply #30 on: May 19, 2020, 09:50:41 PM »
Just a thought---
When I acquired my '63 F-100, it had already had a 390 swapped in. The truck originally had a '6' and automatic. EVERYTHING had been sorta cobbled together and nothing quite fit and many of the parts were worn out. One of the things I didn't cotton on to right away was that the bushing (brass two piece) in the block end of the Z-tube was badly worn. I found that I could source one that was supposed to go in a '57 T-bird and replaced it with a goodly amount of grease. It only lasted a couple of months. In order to fix it, I ultimately replaced the ball-headed stud on the block bracket with a bolt through a Teflon 'doughnut' from a later model car.
I never was completely satisfied with the clutch action even though I'd re-manufactured just about every piece of the linkage. But with Heim joint ends and hardened bushings in the 'wallered-out' holes, it was much better than when I started. Good luck to you!
6667fan
  • Every Second Counts
Re: Clutch Linkage
« Reply #31 on: May 20, 2020, 07:20:08 PM »
Jared, I see your signature now includes 4.71 cogs. Looks like it is gonna be rip city. 4.57s weren’t gonna get you revving high enough? Used to be 4.33s IIRC.  Gonna be fun.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Re: Clutch Linkage
« Reply #32 on: May 20, 2020, 09:06:00 PM »
JB
Good memory, JB. Yes, was 4.33's when I had the clapped out old motor in there...The new one is going to be a little more high strung. I was running some numbers and it came down to a 4.71 or a 4.86. This will be street/strip. I decided for now to try out the 4.71. If I happen to get greedy and slap a 50 shot at it, I should still be fine. I don't mind a little extra noise on the highway, there's a reason I have a radio delete.  :)
wayne
Re: Clutch Linkage
« Reply #33 on: May 21, 2020, 01:15:02 PM »
I like your fairlane sure makes me miss my the one i had.
