Author Topic: My stupid question of the week C6 with a manual clutch  (Read 10962 times)
gregaba
Re: My stupid question of the week C6 with a manual clutch
« Reply #15 on: April 09, 2020, 05:12:01 PM »
When I was 17 I bought a 52 ford 2 dr. I don't know what tranny it had in it but it hurt when it shifted.
It was so hard that I traded the car. I just couldn't drive it every day. I was in pain when I got to school every day.
Greg
57 lima bean
« Reply #16 on: April 09, 2020, 05:19:58 PM »
                     The parallel universe ..  https://brunosautomotive.com/products/
« Reply #17 on: April 09, 2020, 05:22:06 PM »
Imagine then a built L88 with...what? six times the flatheads output? 8)
« Reply #18 on: April 09, 2020, 05:24:39 PM »
Mopars Fluid drive from the 40s? :D
MeanGene
« Reply #19 on: April 09, 2020, 05:28:07 PM »
  That's the real deal Gene! I changed a few "in the day" . Later models were forced to use a flat plate and scatter shield for safety. Your set up is easily worth what you are asking from a "nostalgia" point. The one you have was a joint effort between Ford and B&M. It is loaded with some special parts like the servo assy , valve body , input shaft , band apply lever and IIRC , Vasco Jet out put shaft material.  Tom Grove DID use one because of the convertor explosion in his '66 long nose when he supercharged it after crashing his '67 back east . Not sure about Ronda , M/T did have at least one probably more. Back then it was easy to tell the ones with convertors because of the "convertor lurch" caused by the blower.
   Randy
Thanks Randy, I also have the handmade ratchet shifter that came with it- ran it in my Gal with a regular C6 for a while- actually works pretty well
allrightmike
« Reply #20 on: April 09, 2020, 06:11:59 PM »
Did the clutchflite go away because the internals could not take the abuse?
'60 Starliner 427 4speed.
« Reply #21 on: April 09, 2020, 07:08:21 PM »
Yes, that and too many races were lost due to breakage, the cost was prohibitve and in some cases (no scattershield) too many drivers were seriously hurt in explosions.
« Last Edit: April 10, 2020, 08:14:18 AM by machoneman »
gt350hr
« Reply #22 on: April 10, 2020, 11:11:44 AM »
 Torqueflights have a sprag that "hangs" ( binds) and over speeds the rear drum to the point where it self destructs. that sprag is very sensitive to shock loads like wheel hop or breaking a ring and pimion. THAT is what caused NHRA to mandate transmission blankets ( now shields) on automatic transmissions. Chevy flex plates caused us to have "ring gear shields" even though Fords can't explode or lose a 360* welded ring gear. No "segregation" there , we all pay.
« Reply #23 on: April 11, 2020, 03:54:56 PM »
Back in '68 I was a metallurgical process engineer at T&C Livonia. The process section was adjacent to, and part of, the QC lab in the southwestern corner of the facility. The very front of the property was all a two story administration building, with the Exec garage on the west end. There was an experimental group attached, and it was common for there to be tables lining the aisle with projects laid out for inspection. Quite likely what was the very first 'clutch' C-6 was displayed there for more than a month.
The bell was cut off the case and a scatter shield was attached to the front by way of the pump bolts. A hub from a converter had a fabricated trio of arms welded to it, in such a way as to pick up the release fingers for the Long clutch and so drive the pump. There was a plethora of small parts also laid out for inspection.
After it disappeared from the table, Jon Corrunker told me that he had it, or one like it. He was very adept at scoring one-off items that had gone through an exploration/examination program. Racers who worked at T&C and knew Bruno Zava, the Plant Executive Engineer, could count on a steady stream of 'government job' items being available.
« Reply #24 on: April 13, 2020, 01:32:28 AM »
A friend had a Clutchflite in his 340 Duster for a while. I rode it in a couple times. He ran slicks on the street to cushion the blow and I can't imagine trying to run it with radials. It was a real necksnapper for sure,  the clutch was a sintered iron, heavy pressure plate one so it was on or off, no slipping.
Gene's tranny is cool. Any idea what car it may have been from? I bought a few parts that I think were from the Snodgrass and Mahnken Mustang, they were from that area.
gt350hr
« Reply #25 on: April 13, 2020, 11:31:03 AM »
   Pat Mahnken was an auto trans guy at a Ford dealer here in So Cal.(dare I say Foulger?) . I saw the "canary" race more than once but thought it had a convertor.
    The shifter pictured in the other posts is a Logghe shifter for sure. Tommy Grove retrofitted one to the '66 long nose when it got forced into use after he crashed the '67 back east.
« Reply #26 on: April 13, 2020, 03:48:05 PM »
My basic question is "why".  Auto trans / converter science is about as good as you can get for performance.  And looks like a really good converter can be had for less money than a single disk performance clutch setup which still doesn't include cost of any mods to the trans.
gt350hr
« Reply #27 on: April 13, 2020, 04:40:40 PM »
  Chris ,
    Convertor technology was in it's infancy in '67 let alone '66. A Cammer on nitro would "balloon" the convertor and destroy everything. Anti ballooning plates came along later and almost by accident. The sprag in the convertor  was also a problem and they broke with regularity. We have come a long way since then.
MeanGene
« Reply #28 on: April 21, 2020, 02:51:36 PM »
So, somebody buy this thing! I tried to get Godsey to put it in his funny car lol...
« Reply #29 on: April 22, 2020, 07:56:49 AM »
Forgot to add for gt350hr
 I was planning using a slipper clutch but haven't decided which brand would work best. Will have to do some research.
Greg
I dont think a softlock clutch will help much except when you start. each shift
the clutch is already locked. You dont use the clutch shifting just click in next
"gear". Manual valve body....
Actually, depending on how you set it up, it will "drive through" the clutch on a shift.  That is how a clutchless transmission works it.   The change in power causes slippage, that heat causes it to lock up again.  Shift-repeat.
I can't say all soft loks are the same, but the basic parts are.  How fancy of a unit you want will determine price.  Aluminum pressure ring, billet levers add to the cost.
The real problem will be slow speed driving and putting any kind of load on it.  It will drive through it easily and you will need to be very mindful of your RPM's.  I could drive my wagon to work everyday and not hurt it.  But some people would burn it up before getting down the street.  You can't "play" with it unless you run it up to shift rpm.  Just something to consider.  Back when those clutch flights were popular, every clutch was 3200# and wouldn't slip no matter how hard you tried.
