FE Technical Forum
Cam Thrust Plate Orientation?
Topic: Cam Thrust Plate Orientation? (Read 4098 times)
66FAIRLANE
Andy
March 30, 2020, 07:12:44 PM »
Can someone please confirm the cam thrust plate is installed with the groove facing forward, ie. sprocket side.
gregb
Jr. Member
Re: Cam Thrust Plate Orientation?
Reply #1 on:
March 30, 2020, 08:05:17 PM »
As far as I recall I don’t think you can put it on backwards......it will only orient properly one way.
66FAIRLANE
Andy
Reply #2 on:
March 30, 2020, 08:33:26 PM »
Thanks Gregb. I checked, you are correct. What I didn't notice was that not only are the holes offset sideways but they are not 'centred' on the cam bore. Thus it will only go one way. Should have tried it in the first place! Cheers.
FE Technical Forum
