Author Topic: Dipstick not measuring - Canton pan and tray  (Read 11972 times)
fairlaniac
« on: March 18, 2020, 10:01:29 AM »
Last week I had the engine upside down on the stand and the pan off checking dipstick clearance. Seems to be a nice notch at the front of the windage tray/screen and the dipstick passed freely but did seem angled pretty hard. Finished assembly and added oil. Did some pre-oiling exercises and checked the oil level. It's a Canton 7 qt. pan. I have 7 qts. in but nothing measures on the dipstick. I also hear the dipstick scraping as it goes in the last inch or so. Might be hitting the edge of the tray? I saw an old post of bending the last inch of the dipstick. I guess all I need is some oil to show up on the dipstick and knowing I have 7 qts. I should be good?
I took the dipstick from my 390 that was in my Fairlane to use on the 427. It's a much sloppier fit in the 427 block. I could just add some sealer around the insertion point. Any issues there?
I thought about using the dipstick port in the Canton pan but it seems low and oil would come out if I removed the plug. I assume Canton sells a dipstick and tube for this? Then how would I block off the OEM hole in the block? Seems using an OEM dipstick would be easiest? Any tips or suggestions?
Thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Dipstick not measuring - Canton pan and tray
« Reply #1 on: March 18, 2020, 10:39:08 AM »
When I put the Milodon drag race pan on the 393 in the dragster, I had to actually drill the pan windage and tweak the stick to clear, so IMHO not unusual.  I don't even run a stick now, so not a problem LOL.
On the door car, I use an aftermarket (china) dipstick.  The ring on the stick doesn't meet the block properly and it reads wrong.  I slipped a small clipped piece of hose over it to seal against the block port and just marked the oil level for the 7 qt pan using a chisel.
« Reply #2 on: March 18, 2020, 06:43:43 PM »
Use the Canton dipstick.  Put a cup plug in the block.
338Raptor
« Reply #3 on: March 18, 2020, 07:44:29 PM »
This topic makes me curious about the correct oil level in a pan.  Is there a target oil level?  Since mixing and matching pans and dipstick tubes and sticks there must be an optimum level to shoot for.
For example: On a street engine, should the oil level be 2” below the crankshaft counterweights on an FE engine regardless of the style of pan?
6667fan
  • Every Second Counts
« Reply #4 on: March 18, 2020, 09:00:18 PM »
Doug, what is the part number on that pan? I can’t recall if you went with a T pan or not. The front deep sump pan they offer is a 7 qt system. 6 in the pan and one in the filter. Canton sells a tube and stick package. They might even ship direct to you. You have to manipulate the tube, ( it’s soft), to clear headers and oil filter mount. Can’t bend it too crazy or the stick will fight you going in/ out. Bend the tube, try the stick, repeat until you have clearance from headers, etc and have a removable dip stick.
Good luck,
JB
« Last Edit: March 19, 2020, 06:00:25 PM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Ranch
« Reply #5 on: March 19, 2020, 05:34:58 AM »
I once measured the oil level mark on my dip stick relative to the pan rail.  I believe it was 2 1/2".  That was a stock dip stick on a '62' 406.....Hope that helps
fairlaniac
« Reply #6 on: March 19, 2020, 07:09:02 AM »
Doug, what us the part number on that pan? I can’t recall if you went with a T pan or not. The front deep sump pan they offer is a 7 qt system. 6 in the pan and one in the filter. Canton sells a tube and stick package. They might even ship direct to you. You have to manipulate the tube, ( it’s soft), to clear headers and oil filter mount. Can’t bend it too crazy or the stick will fight you going in/ out. Bend the tube, try the stick, repeat until you have clearance from headers, etc and have a removable dip stick.
Good luck,
JB
No T pan, I have the 7 qt. I did order a dip stick & tube by Canton. Now to figure the size for a cup plug to seal the OEM dip stick hole and if I have one on hand. I'm ready to drop the engine in. I'd hate to have to order a cup plug and wait.............. :-)
Doug Bender
1978 F150 2WD 390
« Reply #7 on: March 19, 2020, 07:13:33 AM »
A 7/16" plug gets you down against the shoulder.  I use a roll pin punch and drive her in.
fairlaniac
« Reply #8 on: March 19, 2020, 01:20:30 PM »
Brent,
The first diameter drilled is about 7/16" but if I put a plug there it will not be surrounded by 360 degrees of block material and it is just sitting on the ledge of the next hole drilled about 3/8". A 3/8" plug will go in the hole and seat on a ledge about 3/8" deep. See pic, I cannot image a 7/16" plug would seal here/
Doug Bender
1978 F150 2WD 390
« Reply #9 on: March 19, 2020, 04:43:30 PM »
A 3/8" plug is fine.
I have shallow 7/16" plugs that will drive down in there, but 3/8" will work just fine.  Doesn't take much, sometimes when I dyno a factory style combo, I'll leave the dipstick out and just shove a bolt down in there, with no leaks or issues.
Your plug will work fine.
6667fan
« Reply #10 on: March 19, 2020, 06:45:06 PM »
Hi Doug,
You are going to want to drain it all out to get back to zero for dipstick marking purposes.  With 7 qts in there you will be over the bung level of that pan anyways, might get messy screwing in the dipstick tube, lol.
JB
JB
67 Fairlane 500
482 cid 700/617
« Reply #11 on: March 20, 2020, 03:12:17 AM »
I think you could plug it with a 9mm casing  ;)
fairlaniac
« Reply #12 on: March 20, 2020, 06:11:03 AM »
Hi Doug,
JB
Yep, got that planned.
Thanks
Doug Bender
1978 F150 2WD 390
« Reply #13 on: March 21, 2020, 03:18:19 PM »
I just knocked the plug out of a 360 from a 4x4. It is a cup plug in the smaller hole down deep.
57 lima bean
« Reply #14 on: March 21, 2020, 09:18:30 PM »
                             https://www.youtube.com/watch?v=qOmMDF8sNro
