Author Topic: Time for another guess the horsepower game....  (Read 27182 times)
Re: Time for another guess the horsepower game....
« Reply #45 on: March 20, 2020, 02:20:37 PM »
My 549 HP guestimate was close!
Yep, just one over!
1968galaxie
« Reply #46 on: March 20, 2020, 02:23:38 PM »
The last contest I was one HP over as well - lol.
Almost as if it was on purpose.
« Reply #47 on: March 20, 2020, 02:30:08 PM »
It was 547.67 hp, which rounds up to 548.  Not on purpose, but I'll send you some decals if it makes you feel better.
wowens
« Reply #48 on: March 20, 2020, 02:39:16 PM »
Missed by 10, had 558
Woody
« Reply #49 on: March 20, 2020, 04:07:24 PM »
Impressive
« Reply #50 on: March 20, 2020, 04:16:01 PM »
It was a good day.  Didn't get to try a bigger carburetor that someone wanted me to try, but we tried a lot of other things.  A 1" Super Sucker didn't add one single number to the peak hp or torque, but it added 10 average hp and about 10 average torque.
Going from 32° timing to 30° dropped about 20 hp.  Going from 32° to 34° added a few ponies over the 32°.
Peak hp was at 5500, but only dropped 5 hp at 6000.
FElony
« Reply #51 on: March 20, 2020, 07:52:01 PM »
I guessed 777 hp. Good thing I didn't type that out loud, 'cuz I sure would feel like a dummy if anyone knew.
« Reply #52 on: March 20, 2020, 11:13:30 PM »
777 would have been bang on if the air way better.... like a cloud of nitrous.
FElony
« Reply #53 on: March 20, 2020, 11:58:35 PM »
I woulda done 666, but I've already been kicked out of hell twice. I guess The Devil was afraid for his job.
« Reply #54 on: March 21, 2020, 07:24:05 AM »
Well done!  I nailed the HP but didn't expect the big torque numbers.  That thing should be a monster and likely has great manners and a ton of vacuum.
KMcCullah
« Reply #55 on: March 21, 2020, 12:41:12 PM »
548 hp at 5500, 580 torque....
Wow! Killer torque. Was this with the 780 carb? Awesome build!
Kevin McCullah
« Reply #56 on: March 21, 2020, 02:03:24 PM »
Almost 1.4 hp per cube. I wasn't expecting that. Those heads are better than I thought. Nice job, Brent!
Doug, hp/ci is 1.23.  But they are good heads!
My bad, I forgot about the stroker crank and based it on a 396 ci. An extra 40 cubes certainly will make a difference..lol
« Reply #57 on: March 22, 2020, 05:23:06 AM »
Yes sir, a Quick Fuel HR-780.
Here's the dyno sheet.  A little bit of an A/F ratio imbalance from side to side.  Could have been the way I shaped the divider, not sure, but a Super Sucker didn't straighten it out and neither did a large air cleaner.  Regardless, it's showing lean because we were tuning for 4500' altitude on the last several pulls since this engine is going to Wyoming.  Makes it a little trickier to manage time efficiently, because we wanted to make sure that it would be close enough on A/F so that he wouldn't have to do a lot of tuning once he got it in the car.  We can even "drive" the dyno to simulate the A/F ratio at cruising rpm, and spent time tuning for that scenario as well.
The torque surprised me as well.  Dynos have a range of repeatability but all torque numbers after the majority of tuning was completed were in the 570-580 range.
One thing to note:  we watch the oil temperatures throughout a pull, as it can be an indicator of issues.  We typically see 2-3° bumps in oil temp throughout a full pull.   There's a trend with the Canton and Milodon pans, in that they are so deep that the oil temperature will start going down through the pull.  The dyno cell has airflow in it and those deep pans act as a radiator.  Pretty neat.
All-in-all, I was very pleased with the engine and I'm a big fan of these cylinder heads.  Making almost 550 hp with a 5500 rpm peak, holding to 6000 with a relatively small camshaft (231° @ .050" intake lobe) says a lot for cylinder head performance.
« Reply #58 on: March 22, 2020, 09:44:13 AM »
Drop that oil pressure down to 50-55 psi, and pick up several horsepower.  Looks like a solid build.  Joe-JDC
« Reply #59 on: March 22, 2020, 10:14:05 AM »
I use a lot of standard volume pumps that end up at around 60-65 psi at full song. I typically don’t do it on hydraulic roller builds that can go over 6000 rpm on a spirited jaunt.
On a long run, the oil temp would go up some from where it ran here, which would cause the pressure to go down a little....prob 10-12 psi.
