Author Topic: 390 still using oil  (Read 30468 times)
Re: 390 still using oil
« Reply #45 on: April 19, 2020, 09:04:21 PM »
i have a whole coffee can full of used plugs,most of them are oil fouled when it was sucking oil with the bad intake seal.i thought i was never going to find out why it was smoking and using oil,til i used ++ amounts of sealer.after that i changed my oil 2500 miles later,and it was still full.i did not add any oil between changes. issues solved!   p.s. my plugs looked exactly like yours,oiled.
« Last Edit: April 19, 2020, 09:06:33 PM by fryedaddy »
390owner
« Reply #46 on: April 21, 2020, 08:48:59 PM »
So all eight of the plugs looked the same?
« Reply #47 on: April 23, 2020, 05:41:27 PM »
No about half were oiled the other half were ok.i guess where my intake wasn't sealed good,it leaked or sucked oil in more than one spot.but i went ahead and changed them all while i was at it.but i finally got it fixed when i threw the sealer to it.
390owner
« Reply #48 on: April 23, 2020, 07:33:38 PM »
That is what I cant figure out all my plugs look the same all black
« Reply #49 on: April 24, 2020, 08:21:35 AM »
mine were all black,but only about half had wet oil all over them
390owner
« Reply #50 on: May 09, 2020, 07:26:24 PM »
I pulled my pcv valve today and put a vent in its place. I then plugged the vacuum port on the base of the carb. I drove it over 100 miles the oil did not move on the dip stick when I checked it after the trip. Will it hurt the engine to not run a pcv? Or if I use a smaller vacuum hose for the pcv will it keep it from sucking oil? Before on a trip of about 80 miles the oil would be 1/4 down on the dip stick every time.
« Reply #51 on: May 10, 2020, 01:55:37 PM »
Won't hurt a thing.  None of my engines leave here with PCV valves.
« Reply #52 on: May 10, 2020, 02:20:57 PM »
Yes, you can use your current hose and plug it with any number of materials after you drill a small hole in that plug, say a 1/8"s or so to limit vacuum. Interesting too is why your engine started using oil after some years, I presume. Often, a valve cover change is at fault where their is zero or inadequate shielding on the head side fo the cover, where oil splash is directly sucked up into the valve. Some sheet metal shielding, like that on OEM Ford covers, is present for that very reason.
In some other posts today, some have had issues and don't like to run a PCV valve. I agree for all-out, competition engines. But, for lesser mortals that only occasionally run up the rpms a lot, that valve does have benefits.
Keep in mind billions of miles (no kidding) have been run by all the makes of cars here in the USA and abroad since PCV valves started up in the early 1960's without any problems. In fact, most of the troubles, even as noted in another post here, relate to possible detonation issues in modified engines and/or unusual oil consumption. Detonation due to oiled combustion chambers is a real issue IF the PCV valve malfunctions or, as noted, changes to the valve covers or other breather related issues, Then yes by all means "hot" engines should not run the valve.
But and IMO, the vast majority of basically street engines we actually "drive" here can likely benefit by running one. The choice is yours.
« Last Edit: May 10, 2020, 02:23:53 PM by machoneman »
390owner
« Reply #53 on: May 10, 2020, 08:11:45 PM »
This is a new engine. I have about 7000 miles on it. It has been using oil since I put it in my bronco. It did get a little better. So that is  why I removed the pcv to see if it made a difference on the oil disappearing it did. Thanks for the input I think I will run it a while without it and see what happens. I would like it to work without sucking oil so I did not smell the fumes. I did change the valve covers back to the stock covers from a chrome set I had on it before
gdaddy01
« Reply #54 on: May 10, 2020, 08:25:30 PM »
what year Bronco ?
390owner
« Reply #55 on: May 10, 2020, 09:07:42 PM »
1979 IMG_1546 by Daniel Crymes, on Flickr
shady
« Reply #56 on: May 11, 2020, 06:29:01 AM »
Nice!
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
BigBlueIron
« Reply #57 on: May 11, 2020, 08:22:51 AM »
Sweet ride!
gdaddy01
« Reply #58 on: May 11, 2020, 03:24:04 PM »
oh yea , I like that , with a fe on top of that , cool .
390owner
« Reply #59 on: May 11, 2020, 08:29:29 PM »
Thanks the 390 pulls it down the road with no problem. This is the second 390 I put in it . I wore the first one out.
