Author Topic: Advice for an FE Forum greenhorn  (Read 11516 times)
Re: Advice for an FE Forum greenhorn
« Reply #15 on: January 26, 2020, 03:29:39 PM »
I tried to attach a pic of the stamping on the GT heads, but will get it figured out for next time.  I assume they are regular C6AE heads.  They do not read C6AE-R.  What does the isolated R and 6090R signify?  I also have a set of C8AE-H which I assume are nothing special?
Does anyone have experience with aftermarket heads and the 6113 headers?
Thanks for all of the help and input fellas.
I am pretty sure, if not 100% positive that the 6113 (and the Mustang version of 6114) are for CJ/early/aftermarket heads.  If you don't see a "U" or "R" you need to measure how low the floor of the port is.  If it's an R, which is just a unique head with a low riser intake port and low roof/high floor exhaust, then you are good.  If it's a U, then it's a small port intake and low exhaust port like your C8AE-H, won't fit the headers and gives up flow for no benefit
U vs R are just application differences and ways to get there, both are common, and likely the R is more common, and preferred
« Reply #16 on: January 26, 2020, 07:33:36 PM »
6090 tells you it is a cylinderhead
« Reply #17 on: January 27, 2020, 01:48:37 PM »
Machine shop prices are all over so it's hard to say "this, that" for any particular situation.  Here, because there are almost no performance shops at all it is a better total investment to buy a kit with everything and then take your block in to get it prepped.  There's one shop left that grinds cranks and he doesn't do it very often.  Most others closed down/retired.  And the one good shop does mostly resto work and diesel repair - few people do their own thing anymore.  They go buy a crate motor.
I spent $2400 on a 393C racing level kit  - name brand H beam rods, pistons, steel crank, rings, bearings, etc.  I already had a decked and bored block.  Sent they guy my black deck measure and requested deck clearance (.005) and all I needed to do was have the block honed out another .001.  Bolted it all in and made 575 HP with it.  The point being that working with a good vendor will get you parts that work right out of the box, vs running around getting this and that done, collecting parts, going back and paying to have it all balanced, etc.
Heads are another thing - depends on the amount of work they need.  You quickly reach a tipping point where you are money and power generation ahead to just buy modern units.  Simple valve job/update, stocker level cam/springs, etc likely no problem.  You start to step up and you should be tossing every bit of OEM valve train equipment.
338Raptor
« Reply #18 on: January 31, 2020, 10:25:40 PM »
What did you decide to do?
T U Bar
« Reply #19 on: February 01, 2020, 11:10:35 AM »
To keep Kevin’s FE attorney at bay, I told the bride to book her dream trip to Hawaii as an anniversary present.  This sure seemed to soften the blow when we discussed the engine build LOL!  I’m not calculative enough to plan things that way, but hey, it worked...
Going with the 445 stroker kit, rpm intake (unless I stumble onto a Streetmaster per Jay), upgraded factory R heads (with CJ valves, POP’s end stands and spacers) and one of Brent’s magic hft cams.
Doug
‘66 Fairlane GT
Yellow Truck
« Reply #20 on: February 01, 2020, 12:00:42 PM »
There is a Holley Street Dominator for sale on "Letgo" in Colorado for $250. According to Jay's research the Street Dominator and Streetmaster were pretty much the same, and needed the same work on the plenum and runner inlets.
You won't regret stroking it.
« Last Edit: February 01, 2020, 12:02:31 PM by Yellow Truck »
Paul.
oldiron.fe
« Reply #21 on: February 20, 2020, 02:10:12 PM »
66' Fairlanes 427 (08/26/67- present)
66/67' Fairlanes
70' Mustang Fastback
66' Dually
DubyaTF
« Reply #22 on: February 20, 2020, 05:11:01 PM »
    Contact Denny or Pam at www.aldridgemotorsportsinc.com. He's where I found my Streetmaster. He may have another in his stash. Super nice, decades of experience and wicked smart people!
Jeff
475fetoploader
« Reply #23 on: February 20, 2020, 05:24:45 PM »
There’s at least 4 street master intakes on eBay right now, if I was a little more clever I would cut and paste the link, I just put 390 intake in the search, a couple of them look to be in great shape.
1967  519 c.i.  TKX 5 speed
T U Bar
« Reply #24 on: February 20, 2020, 06:52:48 PM »
Thanks for your direction gentlemen.
Doug
‘66 Fairlane GT
