Author Topic: Master cylinder quality  (Read 4084 times)
winr1
« on: December 28, 2019, 12:27:29 PM »
Need a new M/S for 2001 Lincoln MKS
Dont mind paying top dollar but not sure which one to get
Have no idea where they are made anymore
Bought pads and rotors for my 2009 F150, told my parts guy I wanted US made parts
They were Wagner, did not look at boxes till I arrived home, rotors were made in china .....
Ford dealer.. Motorcraft 8A8Z2140A
Another supposedly newer
Part Number: 8A8Z2140A
Supersession(s): 8A8Z-2140-A
Motorcraft BRMC-118 Brake Master Cylinder
https://www.amazon.com/Motorcraft-BRMC-118-Brake-Master-Cylinder/dp/B006EI7EOW/ref=au_as_r?_encoding=UTF8&Make=Lincoln%7C55&Model=MKS%7C6828&Year=2011%7C2011&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=6&vehicleType=automotive
Rock Auto has
Raybestos
Wagner
Cardone
Centric
Motorcraft
ACDELCO
Re: Master cylinder quality
« Reply #1 on: December 28, 2019, 08:07:09 PM »
Go to the Ford dealer
When I was at F-M the Wagner division had the Ford service parts account.  The parts for Ford were made to a significantly higher quality level than the parts sold in the traditional market, often from alternate sources and with a concurrently higher cost.
When it comes to something critical like brakes I would rather purchase better parts instead of searching for the lowest price.  Unfortunately it has become almost impossible to identify or purchase high quality products anymore in the traditional replacement market.  Seems we choose between cheap and crappy, cheaper and crappier, or cheapest junk available...
winr1
« Reply #2 on: December 30, 2019, 05:32:46 PM »
Thanks Barry :-)
McRee Ford had a Ford/Motorcraft for $217.00
3 or 4 well known auto parts master cylinders are made in china, the ones that knew that is ..
Ricky.
« Reply #3 on: December 30, 2019, 10:44:27 PM »
When I needed to replace the MC on my '63 Effie ICB, I found it almost impossible to get a replacement. I did discover that rebuild kits were readily available, so I pulled it and tore it down to see how bad it looked inside. Then I bought a kit and a brake hone.
It worked like a charm. I probably spent about $10-15 and it took me about a half hour to do the rebuilding job. I don't remember the cost for the replacement I did find available, but it was surely several times what I ended up spending.
« Last Edit: December 30, 2019, 11:00:53 PM by cammerfe »
winr1
« Reply #4 on: December 31, 2019, 07:19:16 AM »
Thank you KS :-)
Ricky.
« Reply #5 on: January 03, 2020, 05:05:41 PM »
I replaced the MC and the booster on the F-350 about 3 years ago with Wagner chinese parts from rockauto.com.  Nothing bad about any of it, working good.  Same with the rear drums, front pads, headlight assemblies, etc.
winr1
« Reply #6 on: January 03, 2020, 11:18:51 PM »
Ya had better luck than me :-)
Wonder if it whatever iron/steel they melt down.. or different plants ??
I have read on more than a few sites, some of the mills use recycled iron/aluminum ..
The wagner/chinese rotors pads on the front of my 2009 F150 wore quickly
The inside pad, drivers left,  wore down to the metal less than 15,000 miles
All of the rotors were worn way down, I found some old stock rotors/pads from rockauto
They are wearing like the original parts
Ricky.
« Reply #7 on: January 06, 2020, 10:18:34 AM »
Yea, that's a good statement to the current situation - YMMV big time.  Pne set of parts works geed, next set not so much.  Shopping rock auto closeouts isn't a bad idea either.
