Author Topic: Lykins Motorsports 431ci S/O LR, 450 hp, 476 lb-ft  (Read 5362 times)
« on: November 17, 2019, 01:28:13 PM »
Performance Summary:
      Cubic Inches:  431            Dyno brand:  Stuska
      Power Adder:   N/A            Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  452 @ 5500
      Peak Torque:  476 @ 3500
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  FoMoCo C8AE-A, 4.260", 10.150"
   Crankshaft brand, cast or forged, stroke, journal size:  FoMoCo cast 390 crank, 3.780", FE rod journal, ground .010/.010
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat H-beam, 6.490"
   Piston brand, material (cast, hypereutectic or forged), dish/dome volume, static CR:  Racetec, forged, 20cc dish, 9.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  FM 125M10, FM 8-7170CH10, Durabond F24
   Piston rings brand, size, other notes:  Total Seal, 1/16, 1/16, 3/16, standard tension
   Oil Pump, pickup, and drive:  Melling M57HV, Aviaid Cobra pan/pickup, ARP pump drive
   Oil pan, windage tray, oil filter adapter:  Aviaid Cobra pan and tray, POP billet remote oil filter adapter, Cobra remote filter mount
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports 235/241 @ .050", 110/106, .620" lift, hydraulic roller
   Lifters brand, type:  Morel standard travel hydraulic roller
   Timing chain and timing cover:  Cloyes billet timing set, factory timing cover
   Cylinder heads brand, material, port and chamber information:  FoMoCo C3-J heads
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  SI, 2.09", 11/32"
   Exhaust valve brand, head size, stem size:  SI, 1.65", 11/32"
   Valve springs brand, part number, specs:  Comp Cams 914, 150/380
   Retainers and locks brand, part number, specs:  Comp Cams 714, 630, 10° steel.
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports non-adjustable roller, 1.76:1
   Rocker shafts and stands, brand, material:  Harland Sharp shafts, POP stands and end stands
   Pushrods brand, type, length:  Custom Trend, custom lengths per valve
   Valve covers, brand, type:  Tony Branda chrome pentroof
   Distributor brand, advance curve information:  FoMoCo with Pertronix, total timing in by 2800
   Harmonic balancer brand:  Powerbond PB1111ST
   Water pump brand, type (mechanical or electric):  Factory cast iron replacement
   Intake manifold brand, material, porting information:  Sidewinder "J", divider shaped/cut down
   Carburetor(s) brand, type:  Custom Quick Fuel HR-750, dichromate finish
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
Re: Lykins Motorsports 431ci S/O LR, 450 hp, 476 lb-ft
« Reply #1 on: November 17, 2019, 01:41:16 PM »
