Author Topic: Combustion chamber turbulence  (Read 14334 times)
FrozenMerc
Re: Combustion chamber turbulence
« Reply #30 on: November 13, 2019, 01:34:04 PM »
It's somewhat uncommon to see at anything less than at the OEM level in most gas applications, but pretty common in diesels is to install pressure transducers and watch actual cylinder pressure. Doesn't matter if you call it a burn or explosion, what matters is the resulting cylinder pressure curve is controllable and within a range that the hard parts will tolerate. Watching the pressure grafs you can certainly tell when you've gone too far into "explosion" range and start seeing big spikes in cylinder pressure rather than a nice curve.
I'm not 100% sure what equipment the OEM's use. When I was messing around with it I cut up a pair of generic SBC heads on a 350 when I was messing around with it.
On some of the diesel's I worked on it was a service manual "tuneup" to measure each cylinder and adjust fuel to each cylinder to balance the engine. But we're talking stationary stuff here. Still, the perspective watching actual cylinder pressure and how it changes based on RPM and timing, etc. is interesting.
I used to be a Test Engineer at a snowmobile and ATV manufacturer.  We used all piezo-electric pressure transducers to monitor cylinder/combustion pressure.  Along with monitoring crank and cam position to the .01 of a degree, valve position with laser transducers to catch any valve float, and strain gages on each of the petals of the reed valves (2 strokes), it was amazing how much data you could gather.  The flutter experienced by the reed valve petals on an 800 cc 2 stroke turning 10,000 on the pump always fascinated me.  The fact that we could see that movement and graph it precisely in relation to crank position, cylinder pressure, injection timing, or any other wide variety of variables helped dial these engines in precisely.
It was not unusual to record data at 100,000 Hz or more to see exactly what was going on.  Then again, these were $3,000 pressure transducers plugged into $80,000 Data Loggers running inside $3,000,000 AVL AC drive dyno cells.  Definitely not your shade tree mechanic level stuff.
RustyCrankshaft
« Reply #31 on: November 13, 2019, 08:12:16 PM »
  Loss of controlled burn or pressure spikes often compromise the fasteners and "lift" the head off of the block and or gasket , usually resulting in gasket failure. We used to think of it as poor gaskets but now realize it it poor "burn management" LOL. If the fasteners aren't compromised , the next sacrificial part is the piston which more often than not is blamed but not the actual problem.
    Randy
You mean it's not always those "cheap" OEM torque to yield bolts that was the problem!!!??? If you are terrible at tuning use cheap head bolts LoL
I haven't data logged a 2 stroke and watched cylinder pressure and never had the stuff to watch the reed petals. All of that stuff I did mostly on diesels and a few push-rod V8's just for fun while I was figuring out how to run all the electronics.  I did race snowmobiles and quads for a quite a long time and even without an impressive graph data logging the petals I have an enormous amount of respect for what those reed can do.
The pressure transducers I was using, I'm sure they're are better versions now, were also piezo's good to 5k psi but they had a very definite life span and it wasn't as long as you would want (at least not when you have to pay for em!).
But really, when you consider the cylinder pressure, temperatures and everything else that's going on in a push rod engine even at 5000 rpm it's pretty impressive on a basic level of what the material can handle. Especially when you compare it to what we had available 75 years ago, or even 20. I doubt many people driving their 100hp hotrod A or B model Ford's around would have thought it was common to see 500-700hp cars on the show room floor.
RustyCrankshaft
« Reply #32 on: November 13, 2019, 08:56:11 PM »
https://www.youtube.com/watch?v=jdW1t8r8qYc
Here is a better slo mo Briggs and Scrapiron see thru head video. The alcohol one is pretty interesting, especially being such low compression.
