Author Topic: Project Junky Junk  (Read 92858 times)
Re: Project Junky Junk
« Reply #30 on: November 18, 2019, 08:38:30 PM »
Iron for sure....
« Reply #31 on: November 19, 2019, 07:21:43 AM »
I don't plan on doing any port work.  I really don't see the reason to spend a lot of money on this build and I think I can approach 500 hp with the factory heads, ported intake, and some carefully chosen bottom end and camshaft parts.
« Reply #32 on: November 19, 2019, 02:38:30 PM »
It will save me a few bucks to go solid flat tappet as well.  Yays?  Nays?
shady
« Reply #33 on: November 19, 2019, 02:53:52 PM »
I do have an Isky EE-399 I've been saving for a special occasion.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #34 on: November 19, 2019, 02:59:49 PM »
Too much duration for the heads.
MRadke
« Reply #35 on: November 19, 2019, 03:07:32 PM »
Whatever keeps the project under control price wise gets a thumbs up from me.  I'm curious to see what you get out of the old girl, along with the estimated cost to get there.
drdano
« Reply #36 on: November 19, 2019, 03:52:10 PM »
282S?
« Reply #37 on: November 19, 2019, 04:41:20 PM »
282S?
Not enough duration and I’ve rarely seen an FE scenario where a single pattern cam is optimal. It will get a custom cam from me, just need to determine if it’s gonna be a roller or a flattie.
« Reply #38 on: November 19, 2019, 05:12:48 PM »
EE-390 would be fun, I sold one a long time ago to someone, not sure where it ended up
« Reply #39 on: November 20, 2019, 02:34:39 AM »
I would absolutely like to see a solid flat tappet cam used, provided it has similar attributes to the later hyd. roller you plan to use. Be interesting to see a comparison between the solid flat and the hyd. roller camshafts, with the same manners.
« Reply #40 on: November 20, 2019, 06:57:33 AM »
Rory, this is gonna be a "one and done".  Things get expensive, switching from flats to rollers, etc.  Distributor gears have to change, pushrods, valve springs, oiling has to change, the whole nine yards.
gdaddy01
« Reply #41 on: November 20, 2019, 08:14:52 PM »
flat
Tom Gahman
« Reply #42 on: November 21, 2019, 05:41:41 AM »
solid flat.
« Reply #43 on: November 21, 2019, 06:36:49 AM »
I think I'll head that direction.  It will save me some cash.  Even a nitrided flat tappet cam with Trend tool steel lifters is cheaper than a hydraulic roller setup.
I will use my non-adjustable rocker arms and some lightened valves to help out with necessary spring pressures.
If I can find a good set of C0 small chamber cores, it will let me use a dish piston instead of a dome, which will cut down the piston weight considerably.
« Reply #44 on: November 21, 2019, 09:55:00 AM »
I also am a fan of the solid. That its cheaper is just a plus.
