Author Topic: Project Junky Junk  (Read 92836 times)
Re: Project Junky Junk
« Reply #150 on: June 05, 2020, 06:55:39 AM »
Perfect car for a screamin 352!
Gregwill16
« Reply #151 on: June 05, 2020, 08:22:21 AM »
I agree. Maybe we should all tip in for Brent  :)
« Reply #152 on: June 18, 2020, 09:32:33 AM »
I'm all for some donations at this point.
The botched crankshaft grind put me in a bind.  It was gonna cost me about $1500-1600 to find a 361 crank, ship it, have it ground, then ship it back.
At this point in time, I just want to move forward on the thing, so I'm having a 352 crankshaft ground .010"/.010", and I'm putting another set of pistons and rods in it.
« Reply #153 on: August 19, 2020, 08:21:18 AM »
Alright.  Don't even know if it's worth posting anything anymore, except for a written record of the method to my madness....
Snagged a cast 352 crank.  To get things going quickly, I bought a set of Molnar FE rods and ordered some Racetec pistons.  1.900" compression height, flat top, 1mm/1mm/2mm ring pack.
Switched cams again to a solid roller.  Yeah, I know.  Still gonna use my non-adjustable rockers to give them a workout.
Measured bearing clearances and since the crank is .020"/.020" with zero bearing choices, I had to send it to my crank guy to have the journals massaged.
Heads are done.  These are the original heads that came off of Junky Junk.  2.080"/1.600", 5/16" stem stainless valves.  PAC small diameter valve springs set up at 270/670, with Manley titanium retainers.  Compression ratio will be right at 10.5:1.
Carb pieces are on their way back to me.  I had Drew recolor and replate everything.  Can't remember if I've posted this before, but I snagged a Holley 3 barrel, 1030 cfm.
« Reply #154 on: August 19, 2020, 08:28:59 AM »
My prediction is that it's going to behave very differently compared to last time we had it on the pump :)
I think you should try the 500 2 barrel, it was winner that day!
« Reply #155 on: August 19, 2020, 01:45:25 PM »
Any cam timing picked out yet?
Tommy-T
« Reply #156 on: August 19, 2020, 02:26:12 PM »
Man!
Those are some tall pistons! How much do they weigh?
Do you have flow numbers for the heads you're gonna use?
Is it going on the dyno soon?
« Reply #157 on: August 20, 2020, 06:21:54 AM »
Man!
Tommy, the weights are written on them, about 550g.
I do not have flow numbers, but based on what I've seen with these heads in the past, they're gonna go about 250cfm with the current prep.  I wasn't too focused on making the heads work at this point as I plan to let Joe port them after the first dyno session.  Should make a night and day difference.
It won't be too soon.  Got too much other stuff that needs to get done before it.  Hopefully this fall.  I have everything I need, just need to make time.
gdaddy01
« Reply #158 on: August 20, 2020, 01:13:24 PM »
keep up the good work , thanks for sharing .
XR7
« Reply #159 on: August 20, 2020, 10:08:23 PM »
Maybe it is just me... but I sure like the look of those Diamond pistons! As for the RaceTech or any other, do you see any downside to the 2 mm oil ring versus 3 mm or 3/16? I had a pretty smart guy tell me he didn't care for them, didn't explain why though...
« Reply #160 on: August 21, 2020, 05:53:43 AM »
So far so good on the 2mm stuff.  I run a lot of Mahle PowerPak series pistons in my 445's and they come with 1mm/2mm ring packs.   The entire ring pack weighs less than 30g.   As long as the hone job is good and the engine will seal up, I see no downside to using them.   I haven't used anything thicker than a 3mm ring pack in forever and when the 2mm is available, I'll usually hop over to it.
The Diamond pistons with the aluminum rods was a very nice combination of parts.  Maybe one day I'll get to try them, but because of the crankshaft fiasco, it is what it is.   I just want the thing on the dyno and making noise.
Joey120373
« Reply #161 on: August 30, 2020, 05:13:07 PM »
Keep it going! I am a big fan of project junk junk.
« Reply #162 on: August 30, 2020, 05:46:12 PM »
Carb is almost finished.....
Drew did a good job on replating/recoloring the parts for me.
Converted everything to screw in bleeds and screw in IFR and PVCR.
Gotta put the needle/seat assemblies in and I'll be about done.
« Reply #163 on: September 05, 2020, 09:10:18 AM »
I can see the light at the end of the tunnel....
Waiting on T&D to send parts for a high riser build and got the Thunderbird 390 torn down, so I turned to the 352 for a little bit.
Calico sent me my main bearings back so I got those in, crank has been touch ground to adjust clearances, and it's in.  Stabbed a piston/rod in #1 and #5, then set about degreeing the camshaft and checking piston/valve clearances.
I have one of Jay's adjustable timing sets and his 2-piece timing cover, so my plan is to change cam timing on the dyno.  I milled the poop out of the heads to get compression up and had to mill one head more than the other, so that meant that I spent about 2 hours yesterday changing cam timing, degreeing, checking piston/valve clearances on two cylinders/two heads, changing cam timing, degreeing, etc, etc.  Finally got that done.
Got all the pistons/rods in, custom Racetec pistons, Molnar rods, and Mahle 1mm/2mm piston rings.
Timing cover is on permanently.
Melling M57B pump is in there with an ARP drive.  Then bolted on one of my stock-appearing oil pans with the trap door oil control feature.  I don't expect this to be any kind of replacement at all for a nice, deep sump race pan, but it's on there.
Waiting on Cometic head gaskets and my lifters to show up, then I can work on the top end.
Not too excited about the color of the valve covers and intake, so I'll have to think a little more on that.  Otherwise, it's starting to look like an engine.  Obviously the 3-bbl carb won't work with this intake manifold without a spacer or some plenum divider work, so I need to make up my mind on what I'm gonna do there too.
« Reply #164 on: September 05, 2020, 10:35:09 AM »
Looks like crap.  Maybe Chevy orange is more in keeping with that level of work.  ;)
