FE Technical Forum
Paint burns off heads
Pages:
All
Topic: Paint burns off heads (Read 8983 times)
Re: Paint burns off heads
Reply #15 on:
October 29, 2019, 10:43:25 AM »
Thanks
Will give Duplicolor a try.
Reply #16 on:
October 29, 2019, 11:57:09 AM »
Also having the right timing when engine is first started, if its too far retarded it will burn it right off. Plus I get the moisture out of the heads and block before spraying. Usually with just a burnsomatic torch.
Reply #17 on:
October 29, 2019, 12:42:22 PM »
Yup
When I first got the wagon the po said it ran hot. Checked the timing and it ran quite a bit cooler and I had the first piece of the puzzle to make it run nice.
Timing matters.
67428GT500
Reply #18 on:
October 29, 2019, 06:36:28 PM »
Even Duplicolor burns off FE exhaust ports, regardless of preparation. I went through it twice. It goes flat initially and then begins to flake over time. If you're running blue there are three different Ford Blues. The variances are by year.
Pages:
All
FE Technical Forum
