Author Topic: Intake Seating & Carb/Distributor Qs  (Read 6634 times)
Re: Intake Seating & Carb/Distributor Qs
« Reply #15 on: October 03, 2019, 06:32:59 AM »
I took more measurements last night and what I found wasn't good news.  I had a machinist visit and we checked a few areas again, looks like only some of the pushrod holes and bolt holes line up, which means I have an angularity / parallelism issue.  My guess is that the original CJ heads were machined far more than I originally thought.
I guess this pushes the build plan in a different direction, might have to swap heads if I don't want to chase the machining down the rabbit hole.  I know the original intake matches up everywhere but the valve cover rails, so I may just pull the heads, preserve them, and swap in something new that'll also drop CR a little.
I'm considering the BBM Twisted Wedge heads at 75cc.
What is a BBM Twisted Wedge head?
CV355
« Reply #16 on: October 03, 2019, 07:13:58 AM »
The decaf hadn't kicked in yet..
BBM heads, mixed them up with Trick Flow TW...  I've been looking at both, but it looks like the BBM will be less of a hassle for install and better CR for a street car.
http://bearblockmotors.com/bbm-ford-fe-cylinder-heads/
« Last Edit: October 03, 2019, 07:25:30 AM by CV355 »
