Author Topic: Should you buy a Tunnel Wedge intake? Think again...  (Read 19624 times)
HTM101
Re: Should you buy a Tunnel Wedge intake? Think again...
« Reply #30 on: October 11, 2019, 03:20:25 PM »
I've run a TW for about 20 years and always felt the look is great...
That is a nicely screwed together motor.
Thanks!
6667fan
  • Every Second Counts
« Reply #31 on: October 12, 2019, 09:11:00 AM »
Great side by side pic of the two. Dig that VC decal. Very nice.
Thanks for the pics.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
DEANs427
« Reply #32 on: October 12, 2019, 02:42:45 PM »
my comparison was on a 482 w/ iron big F heads, 13:1, factory BU/BT carbs, 600/625 cam w/shell flat tappets, dove rockers, no electronics (nostalgia build)
625hp/590 tq on jay,s dyno originally, (been refreshed since dyno pulls)
10.5x with TW, 10.7x - 10.8x w/ MR in 3300# 56 Ford gasser
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
jgkurz
« Reply #33 on: October 21, 2019, 12:11:38 PM »
I've run a TW for about 20 years and always felt the look is great.  For several reasons I recently decided to remove the TW and installed a new BT 2x4.  I like the BT a lot and it will stay on my engine.
With the TW intake the engine began to get edgy at 2,000 rpm.  With the BT I can putz around at about 1,500 rpm before the edgy factor is annoying.
My car is street-driven and its hard to find a good place to wind it up to 7,000 rpm which is about where the TW starts showing its advantage over the BT.
I agree. The TW wins on looks and on an engine that makes power well past 6K. A street/strip FE with a hydraulic valve train will likely be better off with the Ford or BT 2x4. I'd have a TW on an engine that pulled 7K or has BIG cubes. A 521 with a roller hydraulic might work well with a TW on the street.
« Last Edit: February 13, 2020, 10:35:07 AM by jgkurz »
