Author Topic: Valve covers  (Read 7863 times)
69Shakar
Valve covers
« on: September 20, 2019, 10:49:34 PM »
My 428 build is coming along with the usual hiccups.... tried my powered by ford chrome valve covers and Murphy shows up and says to short to clear valve train... what valve covers will clear rocker stands with studs? Is my only option pent roof valve covers. And will they clear power brake booster?
FERoadster
Re: Valve covers
« Reply #1 on: September 21, 2019, 01:16:57 AM »
Assuming 69 Mustang? Power brake booster may be an issue if you get many aftermarket VC's
PB statement may help your search.
Lots of options but I like the CJ finned covers but they  might not fit your setup with the stands and rockers.
Richard >>> FERoadster
427mach1
Re: Valve covers
« Reply #2 on: September 21, 2019, 07:09:51 AM »
i've got the tall "Cobra LeMans" black finned aluminum valve covers.  They clear the Harland Sharp rockers and the power brake booster/master cylinder.  I don't have the end stands, however, so I don't know if they would interfere with my valve covers.  I tried my factory finned aluminum 428 valve covers and they did not clear the rockers.
Re: Valve covers
« Reply #3 on: September 21, 2019, 07:18:29 AM »
I run Lemans black crinkle, but you could always double up gaskets, gluing them together with 3M yellow
In some cases, with repop chrome PBF, I have pinched the baffles from the bottom too, grab them with Channel locks and make them narrower, which makes a little room, however, it was with Lykins rockers, and adjustable roller may need more room
wayne
Re: Valve covers
« Reply #4 on: September 21, 2019, 08:43:31 AM »
Ebay has some valve cover spacers to help you out.
Yellow Truck
Re: Valve covers
« Reply #5 on: September 21, 2019, 01:32:38 PM »
I've got a set of valve cover spacers that are yours for the shipping. Had to shorten the baffle inside my old covers (cast aluminium) because with the spacers they wouldn't fit under the brake booster.
Paul.
69Shakar
Re: Valve covers
« Reply #6 on: September 21, 2019, 03:05:21 PM »
How thick are the spacers? I am using Brent’s roller rockers with studs . I really like my chrome pbf valve covers for the stock look. Where are you located yellow truck?
CV355
Re: Valve covers
« Reply #7 on: September 23, 2019, 08:06:06 AM »
-reread, post no longer applies
Re: Valve covers
« Reply #8 on: September 23, 2019, 08:19:08 AM »
There are also companies that make extra thick gaskets that help this problem out. Might be able to help get off the rockers without hitting your booster.
SCE #234076 1/4 in laminated (stiffer)
      #134076 5/16 cork
« Last Edit: September 23, 2019, 08:29:56 AM by turbohunter »
JamesonRacing
Re: Valve covers
« Reply #9 on: September 23, 2019, 08:36:49 AM »
The PBF covers have a lot of room inside.  I've seen those used with a lot of different rocker arm setups.
Where are they hitting?  As was stated earlier, you can modify the baffle to clear if that is the only issue.  Going to spacers causes other fit issues in most tight engine compartments.
Yellow Truck
Re: Valve covers
« Reply #10 on: September 23, 2019, 02:01:51 PM »
I am on Vancouver Island (near Sidney) in BC. Spacers are 3/8 inch.
Paul.
babybolt
Re: Valve covers
« Reply #11 on: September 23, 2019, 08:24:08 PM »
Dan Medice makes many different types of valve cover spacers:
https://medicemfg.com/index.php
69Shakar
Re: Valve covers
« Reply #12 on: September 24, 2019, 02:17:43 PM »
The rocker studs and baffle were hitting. I ended up getting 1/2 spacers for the valve covers. The taller rocker base of the trick flow heads was the issue.
6667fan
  • Every Second Counts
Re: Valve covers
« Reply #13 on: September 26, 2019, 11:12:06 AM »
Can you email me? I have something for you.
jwysocki@charter.net
Thanks,
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
