Author Topic: 427 failure analysis. I think I found the problem  (Read 8639 times)
drdano
Re: 427 failure analysis. I think I found the problem
« Reply #15 on: September 09, 2019, 12:03:03 PM »
When I wiped my 428 crank thrust surface my local shop had the crank welded and re-ground.  Wasn't very expensive and now crank thrust is right on the money.  The block needed a line hone as well.
unclewill
« Reply #16 on: September 13, 2019, 07:10:32 PM »
Time for a stroker kit!
