Author Topic: 1968 Colony Park 482  (Read 85523 times)
FirstEliminator
Re: 1968 Colony Park 482
« Reply #90 on: December 31, 2019, 08:46:10 AM »
I will be there. Hopefully the Colony Park will too. Knock on wood, I think this rod bearing snafu was the only problem. Everything else seem to run good.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
6667fan
  • Every Second Counts
« Reply #91 on: January 01, 2020, 06:04:56 PM »
Mark/Dennis, we need a two tons of fun(plus), run off. It will blow people’s minds.
Hope to see both machines there.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Towd56
« Reply #92 on: January 03, 2020, 03:32:30 PM »
JB
My poor little 390 going up against that stroked monster?  Have you no feelings?
« Reply #93 on: January 04, 2020, 10:06:03 AM »
Poor little 390...sure   :)
FirstEliminator
« Reply #94 on: January 09, 2020, 12:22:49 AM »
I found the 482 was losing vacuum at WOT, so I installed an Autolite 2100, .98v.  The 390 will be o-k.
Mark
68 Monterey 390 C-6
FirstEliminator
« Reply #95 on: January 09, 2020, 12:28:38 AM »
 In the process of cleaning things for reassembly, problem #2 was discovered. The crank sprocket slides right over, but the spacer's key was is .090 deep and the woodruff key sticks up .112. Tightening the balancer bolt forced it down until it cracked. This time I will fix the clearance, but also mock it up before putting on the timing cover.
Mark
68 Monterey 390 C-6
« Reply #96 on: January 09, 2020, 07:16:34 AM »
Some woodruff keys just don't fit the shape of the stroker crank.  If you have to file it next round, file it.  I like it a bit tighter than slip fit, but the lower gear shouldn't rock the key up, which is what yours likely did if you got the gear on there, and the spacer can be slip fit.
FirstEliminator
« Reply #97 on: January 09, 2020, 09:04:36 AM »
Hi Ross,
  The key is rocked a little bit with the low side on the spacer side. I will have to file a bit when reassembling.
Mark
68 Monterey 390 C-6
« Reply #98 on: January 10, 2020, 06:39:04 AM »
Hi Ross,
Be sure to be careful on the next one.  What I think is likely happening is that you are not tightening the stack (balancer, spacer, slinger, lower gear) together because of that rocked key.  What you were doing was tightening the gear against the key like a wedge, which could keep it from seating and even allow it to move a little.  Since it was loaded unevenly, when you tightened the bolt with the spacer against it, that's likely what broke the spacer.
I doubt there is an issue, but I would also look close at the lower gear and make sure you didn't muck it up a little at the keyway
When you fit it next time, I'd replace the key for peace of mind, then make sure that the gear goes on without rocking the key (shouldn't take more that a brass drift and small hammer), then the spacer fits on the key (check before putting the slinger and timing cover on).  If you do that, it will load all the parts evenly and you will have no issues.
« Reply #99 on: January 10, 2020, 06:42:22 AM »
Mark, what did you end up with for main/rod bearing clearances this time?
FirstEliminator
« Reply #100 on: January 10, 2020, 07:38:13 PM »
Hi Brent
  I haven't made it that far yet. The screw in freeze plugs need to be removed before I wash the block. 5 of them were leaking before. I ordered some 1 1/16 hex bar stock to make into an Allen. Was supposed to be here yesterday, but not yet. Also I've been sick since Christmas and busy at work. I'm sure next week I will be getting things together. With the new dial bore gauge I will check the crank and rod clearances.
Mark
68 Monterey 390 C-6
FirstEliminator
« Reply #101 on: January 11, 2020, 08:08:37 PM »
The 1-1/16" hex showed up today. After stripping lath and insulation all day I won't be going to the shop tonight. This week I will be putting the engine together, once I find another balancer spacer.
  I had thoughts of heating and bending this hex to make a mammoth Allen key. But I will cut it up to short sections that will fit in a socket. Anyone need a freeze plug driver?
Mark
68 Monterey 390 C-6
6667fan
« Reply #102 on: January 13, 2020, 12:27:59 PM »
Shirley you have another spacer 'round there with all those Merc/Ford parts? Let me know if you can't find one.
JB
JB
67 Fairlane 500
482 cid 700/617
FirstEliminator
« Reply #103 on: January 13, 2020, 01:33:09 PM »
Hey Jim,
   A friend in Connecticut has an extra, though i can say you are a bit closer. I probably have another, but I had to rob this one from another engine.
Mark
68 Monterey 390 C-6
Towd56
« Reply #104 on: January 13, 2020, 11:31:47 PM »
 Mark - I have one here too if you get stuck. Could send it out to you . Let me know
