Author Topic: Edelbrock with t&d, new cam choice  (Read 8051 times)
Re: Edelbrock with t&d, new cam choice
« Reply #15 on: August 20, 2019, 06:35:07 AM »
Thanks everyone.  The heads were done a few years ago and ran with the old cam.  I should have been more clear on that, sorry.
I will get in touch with the guys here and get a cam, lifters, and rockers at the least.
Got it.  Blair and Ross had more intuition about your initial post then.
I agree, you need to change something up.   At the very least, retard the cam timing, try to tighten the lash up a little (works depending on the lobes that are used), etc.  At the most, you could spring for a new bumpstick.  I think you can easily hit your goals with just a little bit of tweaking.
« Last Edit: August 20, 2019, 06:40:58 AM by blykins »
