Author Topic: Milling heads  (Read 18356 times)
JimNolan
Milling heads
« on: December 05, 2012, 07:16:27 PM »
Jay or someone that knows,
     I've got to mill my C1AE-A  heads .024" to give me the 9.7 CR I'm needing. How much do I need to take off the head intake surface so the Streetmaster will fit properly ( or, do you think I even need to take anything off the intake surface). The Streetmaster has never been cut on and the C1AE-A heads ended up with 76cc's, so other than just cleanup of the surface, I'd say they haven't been cut on either.
  Now, I searched your book and I've been all over the internet getting information. I couldn't find anything in your book and the bad thing about the internet is, you get more than one answer.
  I need your advice. I'd like to have some idea of what I need before I take the heads to the machinest. Thanks, Jim PS  I rechecked the head CC's today and filled the chambers until it came out the hole in the glass, and it was 76cc's.
Re: Milling heads
« Reply #1 on: December 05, 2012, 08:20:42 PM »
Half of what you mill from the head if my memmory is right
But at .024 i dont think you nead to take anything
« Last Edit: December 05, 2012, 08:24:47 PM by Heo »
CaptCobrajet
Re: Milling heads
« Reply #2 on: December 05, 2012, 10:47:23 PM »
You really should mill the heads first, then put em on the engine..........torqued, and then fit the manifold.  The bolt holes and the VC rail could be anywhere..............a fit before you mill is the only way to do it.  Block deck, head gasket, and head milling all effect manifold fit.  I would mill my heads, and then set the intake on with no gaskets.  If it is too low, put the gaskets in.  If it is too high with gaskets, figure out what you need to do based on the gasket thickness, and you will hit it right on.  The bottom will probably not need anything at .025 off the heads, so you will only have to mill the flanges on the manifold.
Blair Patrick
Re: Milling heads
« Reply #3 on: December 05, 2012, 10:57:50 PM »
Blair is right, test fit the manifold on the heads first.  I prefer to mill the intake surface of the head rather than the intake itself, but either way works.  If your manifold fits just fine now, before milling the heads, then take the same amount off the intake flange of the heads as you do off the deck surface, .024", and the intake will fit the same, but with a smaller gap between the bottom of the manifold and the block.
JimNolan
Re: Milling heads
« Reply #4 on: December 05, 2012, 11:02:24 PM »
You know. That sounds like the way to go. Jay's book had something about the rail too. I'll have to do more than skim over that section. Thanks, jim
   I've got an old set of gaskets, so tomorrow I'll see where it's at. That way I'll have a better idea of the fit AND the rail before I even start. Thanks guys.
Re: Milling heads
« Reply #5 on: December 06, 2012, 03:25:56 AM »
Hey Jim, some nice looking toys there!  Is that 63 Boxtop a 406?  Anything more to tell us about it?  Thanks
Re: Milling heads
« Reply #6 on: December 06, 2012, 07:48:28 AM »
x3 on the mock up - its the only way to do it.
And do not be surprised to find that the intake needs to be milled "back to square" - more on one end or side than on the other.  We've seen every possible variation on these.  I think intakes tend to twist and warp once removed from the first installation.  Its the only way to explain the variances we regularly see.
Re: Milling heads
« Reply #7 on: December 06, 2012, 09:26:36 AM »
Maybe FE intakes are warped more readily during use due to the extreme size and mass of the casting? Comparing a 302 Windsor intake to an FE, I've wondered if this has more to do with your statement.
JimNolan
Re: Milling heads
« Reply #8 on: December 06, 2012, 09:48:18 AM »
Bruce,
   It's a 396ci block with the 406 parts. The only thing that isn't a 385hp/406 is the block, cam and 1.73 rocker ratio. The cam was special made to replicate a 385/406 but in hydraulic format. The forged pistons I used gave me a 10.38 CR. I used maddog headers, Xpypes and 2.5" exhaust. The only thing firewall forward that isn't powercoated is the tye rods, ball joints and springs. I ended up with a 365HP engine (Dyno5). I don't know that I'd do it again. Finding the original 4V aluminum intake, grooved crank and 67cc heads with 2.03/1.65 valves was costly. Finding an original block in good shape is impossible. I got it finished at the first of the year and it's got about 10K miles on it now. 16 mpg @ 65-70mph with 2.75 Trac-Loc. Thanks
JimNolan
Re: Milling heads
« Reply #9 on: December 06, 2012, 04:43:56 PM »
Guys,
   I got the intake mocked up today. Since I'm having .024" taken off the heads and I'm using .020" steel shim head gaskets, I just bolted the heads to the motor without a gasket. That put me within .004" from where it will sit eventually anyway. I bolted the intake on using the same intake gaskets I'll eventually use but old used ones. The intake rails were higher on all four cormers, front right = .031", rear right = .050, rear left = .021, front left = .050. I had the distributor installed when checking.
   Since I know I'm in the ball park and all the bolts fit, I'll go ahead and have the head work done. Then, I'll decide if I want to mill the intake rails on final fit.
   I talked to my machinest ( he's at a show in Indy now, he makes custom Rods for people all over the world that go in engines I've never heard of ) and he said he was planning on milling the heads, doing the pocket porting and installing the valves but the runners were just getting cleaned up at the first inch, exhaust and intake. The runner part I don't understand. My exhaust ports dump out into larger chambers on the headers and the intake runners dump into much larger intake ports on the heads. What would working on the runners accomplish. I could run two sets of Streetmaster intakes into the intake ports of the C1AE-A heads I've got. How the hell Jay got that much horsepower out of those little bitty intake runners on a Streetmaster is suspicious. LOL  PS  I forgot to put that the gap at the bottom front and back was .148", the cork gasket is .170". I think it'll be good.
« Last Edit: December 06, 2012, 05:28:31 PM by JimNolan »
Re: Milling heads
« Reply #10 on: December 06, 2012, 05:05:02 PM »
well im no expert but i think on the C1heads the floor of
the intake port dont see so much flow and there is where
they are bigger than later heads. The flow hapens on
the roof side radius
JimNolan
Re: Milling heads
« Reply #11 on: December 06, 2012, 07:41:30 PM »
After doing the math, given the intake surface of the head can be cut on a 1-1 bases as the deck surface. I surmize I can cut the intake side .025" and the deck side of the head .024", that will reduce the Streetmaster valve cover rail mismatch to .029". That way I won't have to cut the intake.     .029" shouldn't be that much of a detriment to misalignment. Especially if I use a cork valve cover gasket.
« Last Edit: December 06, 2012, 07:44:15 PM by JimNolan »
427highriser
Re: Milling heads
« Reply #12 on: December 07, 2012, 02:27:55 AM »
what head gasket do you have? we tried the .020 one's  and wound up with around .030 on the crimped ones and around .033 on the doubled over ones??? jack
JimNolan
Re: Milling heads
« Reply #13 on: December 07, 2012, 08:41:12 AM »
Jack,
    It's the MRG-1132G. Mr. Gasket .020 steel shim w/4.42" hole. I used them on the other engine also. I don't know if they are crimped or doubled over. Don't they make anything as advertised anymore. Looks like they could take a piece of metel, put 90 lbs of torque on it and mike what they had left and advertise it that way. You guys that do this all the time are a wealth of information.  Jim
PS.  Boy, I hope you're right about the head gaskets I'm using. That'd put me within .024" at the two highest points and near even at the other two.  That'd work for me.
« Last Edit: December 07, 2012, 08:55:51 AM by JimNolan »
JimNolan
Re: Milling heads
« Reply #14 on: December 07, 2012, 12:04:58 PM »
I just alleviated the possibility of a warped Streetmaster intake. All it took was $359.95. I'll refigure the alignment in a few days. Jim
