Author Topic: It's been a while.....time for another guess the horsepower game....  (Read 19353 times)
This one will challenge your brain some.  To be honest, I'm not even sure what it will do because it's got some cylinder heads that I didn't have a part in.
This is a class pulling truck engine.
*Factory 428 block, half-filled, 4.160" bore size
*Calico Coated Federal Mogul 125M main bearings, with coated Clevite H-series rod bearings
*Scat 4340 4.125" crankshaft (makes for a ~450 ci combo)
*Molnar 6.800" rods
*Racetec domed pistons, with a 1.5/1.5/3mm ring pack, compression ratio sitting right at 13:1
*Pistons sit about .008" out, using Cometic 4.250" x .051" gaskets.
*Camshaft is one of my custom billet core solid rollers.   It's 257/267 @ .050", .640"/.650" lift, 112 LSA on a 112 ICL
*Morel solid roller lifters
*Les Schmader ported D2TE-AA cylinder heads.  I got them and they had 3/8" valves, I stuck some new bronze valve guides in them and a set of SI stainless 2.09/1.65 11/32" valves with one of our valve jobs.  I have no clue what these puppies flow.  My guess is about 280-290 cfm.
*Cylinder heads are set up with PAC dual springs, PAC titanium retainers.  270 lbs seat pressure with 600 lbs open.
*Harland Sharp adjustable rockers with Harland Sharp HD shafts, POP billet spacers, stands, and end stands.
*Custom Trend 3/8" x .135" pushrods
*Intake is a very well ported (done by my boy, Lawes Mayfield) Portosonic.  It will have a 2" HVH Super Sucker on it, with a Quick Fuel Q-950 carburetor
*MSD distributor, locked out
*Oiling is taken care of with a Melling HV pump, ARP shaft, inside of a Milodon 9 quart 4x4 truck pan
*No accessories will be turning on the dyno, will be driving the mechanical water pump with an external electric motor
The plan is to have it on the dyno this Friday.
As always, the game is for ****uncorrected**** horsepower.   The closest without going over wins some Lykins goodies.   I'll throw this in the pot too:  the closest without going over combined with the peak hp rpm (guess in 250 rpm increments) will have an opportunity to buy a set of my non-adjustable rockers for $100 off retail price.  They sell for $450, I'll let a set go for $350 if you so desire.  If none of that makes a bit of sense, let me know, and I'll try to clarify.
Happy guessing.
fastf67
Re: It's been a while.....time for another guess the horsepower game....
« Reply #1 on: July 28, 2019, 10:57:58 PM »
I'll throw 632 hp out as a start, and thinking i'm a little high. Please post the torque curve. That will be real interesting to see with 112s
338Raptor
« Reply #2 on: July 28, 2019, 11:51:41 PM »
540 hp @ 5,750 RPM.
« Reply #3 on: July 29, 2019, 04:34:20 AM »
I think you’re a little high too, especially uncorrected numbers.
The longer lobe center should broaden the curve and extend it higher where we need it.  I’ve used up to 119 degrees LSA on some other engines that pull sleds for a living.
Jim Comet
« Reply #4 on: July 29, 2019, 06:12:25 AM »
How about 573 @ 6250rpm. Interesting built, thanks for sharing. Jim
447 Stroker
« Reply #5 on: July 29, 2019, 06:40:29 AM »
540 hp at 5900 RPM
« Reply #6 on: July 29, 2019, 06:44:59 AM »
587 @ 6350. This thing is gonna sound great!!. Torque i think will be about the same maybe 5000 rpm??
Twinibeam66
« Reply #7 on: July 29, 2019, 08:04:53 AM »
549 @ 6100
shady
« Reply #8 on: July 29, 2019, 08:20:17 AM »
561 @ 6500
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
DuckRyder
« Reply #9 on: July 29, 2019, 09:32:55 AM »
Heads being a bit of an unknown...
I’ll throw in 499 @ 5250...
Robert
JamesonRacing
« Reply #10 on: July 29, 2019, 09:45:06 AM »
519hp @ 5950 rpm
« Reply #11 on: July 29, 2019, 09:47:19 AM »
515 hp at 6000 rpm.
jwrmach1
« Reply #12 on: July 29, 2019, 09:49:16 AM »
535 HP @ 6200 RPM
6667fan
  • Every Second Counts
« Reply #13 on: July 29, 2019, 10:44:40 AM »
593@ 6900 rpm.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #14 on: July 29, 2019, 11:23:46 AM »
133 hp swing so far!
