Author Topic: Vacuum leak around intake bolt holes  (Read 15890 times)
Dieselman966
Re: Vacuum leak around intake bolt holes
« Reply #30 on: August 15, 2019, 04:02:49 PM »
Has anyone ever checked for manifold vacuum leaks before putting the rocker shafts back on. I was thinking I could use my hand vacuum pump and check for leaks before putting it all back together.
GerryP
« Reply #31 on: August 15, 2019, 05:20:59 PM »
If you try it, have someone record a video of it and post it up.
Dieselman966
« Reply #32 on: August 15, 2019, 10:57:32 PM »
I tested for vacuum leaks by torquing the intake down and putting duct tape over the carb opening with the carb gasket and lifting plate bolted down.  I pumped it down to 10" of vacuum.  And it took 1 minute 32 seconds to come down to 9" of vacuum. I cant imagine it getting much better than this.
« Last Edit: August 16, 2019, 04:41:43 AM by Dieselman966 »
67428GT500
« Reply #33 on: August 16, 2019, 12:39:16 AM »
There's no way that would do any better than that considering. It would sound as if you're good to go!
