FE Technical Forum
Starter ear grinding.
Topic: Starter ear grinding. (Read 3142 times)
428 GALAXIE
Full Member
July 27, 2019, 09:26:26 AM »
I have to make room for mini starter and it's hitting to the "ear" below starter hole.
Is it solid chunk or hollow am at risk making a hole to inside of engine.
My memory is saying it shouldn't be problem just making sure.
Mikko
gregb
Jr. Member
Re: Starter ear grinding.
Reply #1 on:
July 27, 2019, 09:46:36 AM »
Not going to hit anything it's solid, but it does have that threaded hole where the bellhousing bolt goes. I haven't seen one hit there, did you have to rotate it way around?
428 GALAXIE
Full Member
Reply #2 on:
July 27, 2019, 11:12:22 AM »
Imi starter.
Fits only in one position and this position took all kind of grinding and had to Chuck the mounting plate to lathe get more engagement to flywheel ring gear and get bit more gear "lash"
The body of starter too thick by the neck to directly fit for block.
Mikko
FE Technical Forum
