Author Topic: Exhaust valve to bore clearance 4.155 bore.  (Read 2843 times)
67428GT500
« on: July 18, 2019, 11:44:29 PM »
I mocked up the Edelbrock heads on the block.  I have the springs off, with a spring retainer and and keepers. The valve will move about .800 before the bottom of the retainer bottoms out on the guide. At that point I have .050 clearance between the cylinder wall and the side of the exhaust valve at the above mentioned specs. There is no head gasket installed, however the Felpro 1020 is .041 compressed.
My cam is 5.76 lift.  Do all concur that the .050 is sufficient bore to valve clearance on the exhaust valve?
The 2.19 intakes have a ton of cylinder wall to valve clearance. I was surprised.
        -Keith
Re: Exhaust valve to bore clearance 4.155 bore.
« Reply #1 on: July 19, 2019, 05:09:30 AM »
.050 is fine, and with less lift and deflection, you will gain from there. Might be a good idea to check all 8 though.
« Reply #2 on: July 19, 2019, 06:20:41 AM »
We all told ya... ;)
Add the gasket and it will go way up.
You are fine
67428GT500
« Reply #3 on: July 19, 2019, 06:30:26 AM »
Okay, okay, okay...  Forgive my paranoia.  Now if someone will answer my question on the King Trimetal bearings so I can order them so I have them Monday and can get this thing back in the car.
        -Keith
