Author Topic: c6 gearvenders od  (Read 10665 times)
TimeWarpF100
Re: c6 gearvenders od
« Reply #15 on: June 10, 2019, 10:27:21 PM »
I have a hard time justifying a GV unit when I can change to a TKO for 3376.00.
I cannot justify spending 1500+ more $ and a whole bunch of extra time switching to a TKO vs what he has now.
67428GT500
« Reply #16 on: June 10, 2019, 11:28:47 PM »
It's not 2,000.00 for a GV for a Top Loader.  It Is 3,235.00. I would have been all in at 2K as long as I didn't have to modify the floor board or drill holes or cut wiring harnesses.
        -Keith
« Reply #17 on: June 11, 2019, 07:17:22 AM »
It comes with everything you need and only a couple hours labor to change back to stock.
LOL! We'll see how that works out for you.
« Reply #18 on: June 11, 2019, 10:24:26 AM »
Quote
You are throwing out crap here. I went through Modern Driveline. You don't need a bellhousing. I am having the new Centerforce re-hubbed being there is 390 miles on it and it requires NO modification to fit and sits in the stock location, bolts onto the OE bell housing and linkage.  There is no ect. It comes with everything you need and only a couple hours labor to change back to stock.
I also wind up with a final drive of .064.  Nice cruising gear.  It's also nice they recognize those of us who served this nation with a 10% discount.
By the way, Summit does as well.
Now I agree with you that I wouldn't butcher my Shelby's original driveshaft for a conversion. There
I posted what I did based on your incomplete description of what you had and where you were going.  If you have the balance of the equipment, then of course it's a different cost perspective.  Only providing reference info without benefit of the back story.  Agree - your discount is more than well earned.
TimeWarpF100
« Reply #19 on: June 11, 2019, 01:12:23 PM »
        -Keith
https://www.gearvendors.com/product/automatic-3-speed-c-6-14-tailhousing/
2795.00 with free shipping. Its complete kit
Add 1500 by the time it's installed plus a TON more of labor.  He has a automatic now by the time you add pedals, bellhousing, clutch, flywheel, shifter and all other needed it would be very difficult to do for less than 1500.00. A few hours labor vs many days or weeks to get it done.
« Reply #20 on: June 11, 2019, 02:17:38 PM »
yes it has a good c6 already in it.i wanted to keep it simple as possible.i dont want to start all over from scratch.good info,thanks guys
TimeWarpF100
« Reply #21 on: June 11, 2019, 02:32:38 PM »
You will love the GV if you go that route. Ease of install too
67428GT500
« Reply #22 on: June 11, 2019, 03:13:21 PM »
I looked at GV and was wondering about the hone o drive as well. The GV site shows 3200.00. I'm not going to hammer or cut on a real GT500.  Modern does it as a kit.  Trans with shift lever, cross member, adapters for back up lights and speedometer cable and rear yoke. They offer it as plug and play. I can remove, replace and adjust a T&C in less than 45 minutes on the floor.  I wasn't referring to anyone else changing to a manual.
gt350hr
« Reply #23 on: June 11, 2019, 03:22:28 PM »
  The Hone OD is more bulky than a GV and noisier. I used to be a dealer for them 45+ years ago.
   Randy
AlanCasida
« Reply #24 on: June 11, 2019, 05:25:17 PM »
Over the years I have purchased three GV units used, off of Ebay. I paid an average of $1000.00. They still pop up now and then and they were pretty popular in RVs so you might be able to find one at a salvage yard.There is not really much inside of them to go wrong so the chances of getting a good unit is pretty good. Just another option to consider.
« Reply #25 on: June 11, 2019, 05:45:22 PM »
   Randy
I always wondered about these.  Don't the ever changing pinion angles mess with these?  Seems like it would be an issue, but I don't know.
« Reply #26 on: June 11, 2019, 06:18:37 PM »
You put them on the rear end? I dont know the weight of them
but you get more unsprung wheight and thats not a good thing
66FAIRLANE
  • Andy
« Reply #27 on: June 11, 2019, 08:54:03 PM »
If I had my time again I would have bought the kit with the shortened output shaft & pulled the trans.
gt350hr
« Reply #28 on: June 12, 2019, 11:00:06 AM »
   Randy
        Drew ,
           I did one on a Mustang ( with 4.57 gears) so the guy could quit trailering and drive his car to the track.  The Hone unit was so long ( IMHO) that it changed not only the driveshaft angle ( still acceptable) but the "leverage" caused by natural torque reaction broke the case and threw the pinion out on the starting line, The nodular iron case was not damaged but the Hone "flange" was destroyed.  Hone manufacturing ( local to me) had never seen it , trying to blame me for it happening. WRONG.
          I quit using them after that.
    Randy
