Author Topic: Blair Patrick thanks for my Tunnelport for my 69 Torino Cobra project  (Read 107408 times)
Re: Blair Patrick thanks for my Tunnelport for my 69 Torino Cobra project
« Reply #15 on: December 30, 2012, 03:39:32 PM »
That really looks fabulous, Rob.  Beautiful work, and from all appearances very, very functional.  You need to make a trip to Indy or Daytona and wring that thing out  8)
fetorino
  • Tunnelport Cobra
« Reply #16 on: December 30, 2012, 06:22:32 PM »
that style shock is to rigid  ;D just saying
But so cost effective ;D  Once the car is assembled I will corner weigh it and order the shock and spring package.  JJ @ JRI shocks will be my point man on helping me with my initial spring rate and shock valving choices.  Still a long way to go till I get there.  Now I have to get off my butt and do some real work on the car.  Brakes, plumbing, wiring, accessory brackets, ext.
« Last Edit: December 30, 2012, 06:30:38 PM by fetorino »
fetorino
  • Tunnelport Cobra
« Reply #17 on: December 30, 2012, 06:24:58 PM »
Correct on both counts.  Panhard bar and it's a long one frame rail to frame rail so the lateral deflection through the suspension travel is nil.  The rear splined sway bar isn't installed in the rear photo but it's there also.
That should handle like a dream for sure.  The craftsmanship is incredible.  What brake setup are you going to be running?
Wilwood 6 piston billet narrow supelight radial mount calipers on 14" rotors in the front and 4 piston radial mount billet narrow superlight calipers with integrated parking brake and 14" rotors in the rear.
fetorino
  • Tunnelport Cobra
« Reply #18 on: December 30, 2012, 06:27:55 PM »
I'm starting out with some open track days at Buttonwillow, Fontana and Willow Springs and will run in the Silver State Classic.
At some point I will do a standing mile event.  In between now and then I'm studying up on aero with a real focus on underbody stuff since I want the body to stay stock.
fetorino
  • Tunnelport Cobra
« Reply #19 on: December 31, 2012, 01:50:06 PM »
Mario had asked me about the step by step in how the chassis was built. At this point I can only take credit for having the idea to build the car, finding the shop and stripping the car down and getting it to them. I made some design decisions along the way but the heavy lifting was done by the guys at the Roadster Shop.  Well I am picking out all the parts and will be doing al the plumbing, wiring and final assembly work.
But building a chassis like this way over my head. :o
Cut out the old frame rails front and rear.
Measure and make a template to cut some frame rail sides out of 10ga on your high dollar living room sized cnc cutting table.
Then take those sides and put them in a jig and mig weld the seams in 4" increments so they don't warp.  They do it numbering 1-4 weld all the 1 sections then onto the 2 and so on.  This gives you frame rail parts.
Then it starts looking like a frame on the table.
Then you test fit repeatedly
Build a set of rear rails and add them into the equation.  Oh and keep measuring.
Easy right?
The front crossmember is a modular design that they make in two widths.  All the pickup points for the control arms, steering mounting points are fixed on the crossmember.  This allows them to have all the suspension geometry sorted out and then plug it into any frame rails they build.  For the rear they have an IRS with a 9" based third member $$$$$ but super trick and then they will build you a 4 link, 3 link or truck arm if you want for your solid axle.  The 4 link on mine is a compromise for packaging ease and cost but they have run their 4 link geometry in plenty of events and it works well.  I have a budget so I had to back away from my original plan of a custom 3 link or my day dreaming of their rear IRS.
« Last Edit: December 31, 2012, 02:02:10 PM by fetorino »
dragnfe
« Reply #20 on: January 08, 2013, 08:58:48 AM »
Wow!...Very nice...
fe66comet
« Reply #21 on: January 08, 2013, 01:26:26 PM »
Yup it will be one sweet ride when complete, I love the chassis it is the bomb!
bartlett
« Reply #22 on: January 10, 2013, 06:29:39 PM »
dare I ask what they charged for the work ?
fetorino
  • Tunnelport Cobra
« Reply #23 on: January 16, 2013, 10:47:54 PM »
Finally coming home
silverton_ford
« Reply #24 on: January 25, 2013, 07:16:42 PM »
Very impressive!  I really like the look of this car when it has all 4 tires under it.  Very very nice!  Ball park figures....what does it cost to have that frame built?
My Cars:
- 1969 Fairlane Cobra fastback "R" code 428CJ 4spd
- 1965 Mustang Fastback
- 1930 Model A Roadster
- 1931 Model A Sedan
- 1956 F100
- 1978 F100
- 1978 F250
fetorino
  • Tunnelport Cobra
« Reply #25 on: January 26, 2013, 12:16:39 AM »
It will look better when I get the sized rear tire on there.  The rear will be a 345 30 19 which will be 2" taller than the one in the picture.  The front tire will be about 1/2" taler than the current roller.
Are you sitting down?  A chassis like that is like a cammer, Not cheap.  Figure $15k+ depending on what car and what extras you may want.  For an additional $7k they will do a 9inch based IRS that is good for 1000hp instead of the live axle.
Phil and Jeremy Gerber and their dad Neal are great people and real hot rodders.  They will do anything from a minor project to a full blown car build.  I watched a 61 Corvette they built go across the block at Barret Jackson for $360k
My stuff was small potatoes but they treated me great.  Even brought my car to BJ when they came out to save me shipping.
bartlett
« Reply #26 on: January 26, 2013, 02:27:56 PM »
15k does not sound out of line , looks like a shit ton of work and they look to be top notch.. can't wait to see your car run ...
chris_r
« Reply #27 on: February 18, 2013, 03:14:21 PM »
I really like your frame under your torino i need to pick your brain sometime.
fetorino
  • Tunnelport Cobra
« Reply #28 on: February 18, 2013, 10:38:03 PM »
PM me anytime.  If there is something I know, that you don't,  I would be glad to share.
I did some work this weekend.  Removed all the stock AC box and vents and started thinking about the postioning of my dry sump tank.
I also started mocking up the seating position.
69Cobra
  • A goal without a plan is just a wish
« Reply #29 on: February 19, 2013, 10:07:47 AM »
Very nice build Rob! I love those old cars. I'm kind of in the same boat as you. I've got a Stocker motor coming from Blair and my car is at the chassis shop getting a new chromoly cage etc... I also just took out the old heater case and removed all the factory wiring. As far as the wiring goes I'm going with RacePak's new Smartwire. I don't know if you've looked into this but its a pretty cool little deal. Everything is programable. I'm also going with a V300SD data logger from RP and it works hand in hand with the Smartwire. For example it will read your sensors coming through the data logger and say turn on your fan at 160* or whatever you program it at, turn it off a 100* etc... I'm going to run everything through it and program it accordingly. For example in a drag car application. I have a clutch switch and I'm going to have input switches for every gear. So I can tell it that when it see 1st gear input and the clutch input to activate the 2 step and shut off the fan for X amount of seconds and when it has 4th gear input to not enable the brake lights (so my competition doesn't see my game lol) Etc... Anyways, I didn't know if you already had something in mine but its worth going to RacePak's website and checking it out I think its a pretty cool little deal. It also does away with relays and fuses as its a solid state device. You can set amperage limits for a circuit and if it exceeds that it will shut it down and or retry for how ever many times you tell it to. Anyways I thought you might be interested in it.
Kris Rachford
69 Cobra 428 CJ Jerico 4 speed
NHRA C/Stock Eliminator 3032
