Author Topic: off idle miss  (Read 10996 times)
Re: off idle miss
« Reply #15 on: April 17, 2019, 02:11:00 PM »
i just got back.no change it still sounds like a studder box set on 1500-2500 rpms.if i run it hard you would never know somethings wrong with it,but if you barely mash the pedal it sounds like it wouldn't fall out of a tree if you kicked it in the ass
Re: off idle miss
« Reply #16 on: April 17, 2019, 02:22:42 PM »
maybe i have a damaged front accelerator pump diaphragm.i have been messing with it a week or 2 ago
Re: off idle miss
« Reply #17 on: April 17, 2019, 02:32:32 PM »
I have filled up once when the tanker was at the pump
drowe a few miles from the station before it died. water in the fuel
so i would test with a separate gas can
Re: off idle miss
« Reply #18 on: April 17, 2019, 03:36:17 PM »
maybe the water wont burn good at low rpms and when i go faster its getting so much gas that it dont bother it as much
« Last Edit: April 17, 2019, 03:38:03 PM by fryedaddy »
Re: off idle miss
« Reply #19 on: April 17, 2019, 04:06:13 PM »
And the water does not vaporise as easy as the gas
so att low rpm maby big waterdroplets shortening
the plugs.....or something
Re: off idle miss
« Reply #20 on: April 17, 2019, 04:41:25 PM »
im going to drain my fuel cell,put some fresh 110 in it and put in a set of plugs tomorrow. i believe i will get some new carb base gaskets,i have reused the ones on it now several times  if that don't help then its back to the drawing board
« Last Edit: April 17, 2019, 06:11:21 PM by fryedaddy »
Re: off idle miss
« Reply #21 on: April 17, 2019, 09:11:45 PM »
i went ahead and took out the spark plugs.i checked them a week or two ago and they were nice and toasty.now most are sooty but the tips of the electrodes are white.i cant put the new ones in till tomorrow.
Re: off idle miss
« Reply #22 on: April 18, 2019, 09:24:22 AM »
new plugs didn't help any.it still misses at low rpm and will smooth out when you squeeze the pedal down a little further i cant tell if its a misfire or vac leak or fuel issues or other.
Re: off idle miss
« Reply #23 on: April 18, 2019, 09:40:20 AM »
i think i may have found the problem.i cant fire it up till grandkids wake up but i just noticed both the hot and ground coil wires were loose on the coil.could this be the problem?
« Last Edit: April 18, 2019, 10:22:32 AM by fryedaddy »
Re: off idle miss
« Reply #24 on: April 18, 2019, 01:55:33 PM »
well,i guess it was spark related.tightened the +- on the coil and its running some better. a week spark would explain why my plugs went from toasty to sooty all at once.i would be more worried if it was 1 or 2 cylinders instead of all of them.i think i need to get a new cap and rotor to get back to 100%.i put a used one on while trouble shooting and my other one is a year or 2 old too.could it be a exhaust leak causing that strange sound.i have hookers into 3 inch x pipe and 3 inch mufflers.the guy at the muffler shop told me to tighten the pipes up after some miles
« Last Edit: April 18, 2019, 09:25:27 PM by fryedaddy »
Re: off idle miss
« Reply #25 on: April 19, 2019, 01:16:56 PM »
looks like at this point i will have to be a parts changer. replace everything till i find it.
Re: off idle miss
« Reply #26 on: April 20, 2019, 09:42:05 AM »
i know this is getting to be a boring topic.if this will help any in diagnosing my problem.i went for a ride and it misses or studders or stalls or whatever its doing when you are barely pushing on the pedal.it dont matter if you are crusung at 25 or 55,when you barely mash the pedal is when its doing whatever its doing.when you mash down a little harder on the pedal it smoothes out.even when i let off the gas it does this right before i let completely off on the throttle  any ideals anyone
C8OZ
Re: off idle miss
« Reply #27 on: April 20, 2019, 10:27:44 AM »
Can you get it to do this with a light power-brake sitting still?
Re: off idle miss
« Reply #28 on: April 20, 2019, 11:12:12 AM »
thanks for the reply but i just solved it.i had to go to a chevy website to get someone to reply and figure it out. sorry,low blow just kidding.ok here it is.it was my modulator line clogged.blew it out with a air hose and a bunch of goo came out and now i cant make it miss.i tried.  its fixed.now lets end this stupid topic.no more replys from me.whew i feel better now.
Re: off idle miss
« Reply #29 on: April 20, 2019, 11:22:36 AM »
The modulator line for the transmission? I'm at a loss as to why that would cause a low speed miss, or any miss period, for that matter.
