Author Topic: What did my 428 come out of?  (Read 3531 times)
happystang
« on: April 09, 2019, 10:06:01 PM »
I'm curious, any way to tell what my 428 came out of? I can't find a VIN stamped anywhere on it.
C6ME-A
6M14 date code
"A" scratch on back
1U crank
Re: What did my 428 come out of?
« Reply #1 on: April 09, 2019, 10:21:58 PM »
Most likely a 1967 full sized Ford, Mercury, or Thunderbird. Whan are the head casting numbers, which will most likely have only the 2 bolt vertical exhaust bolt pattern.
« Reply #2 on: April 11, 2019, 08:47:33 PM »
thats my blocks im using.mine are out of 66 thunderbirds.they are good blocks in my opion.the last one i took to the shop,the crank did not need turned.shop owner said it would last me a lifetime.the block did not even need bored but we freshened it up to .30 over because i already had pistons this size.we put arp studs in the rods and mains.good engines imo
67428GT500
« Reply #3 on: April 11, 2019, 09:00:08 PM »
My 1967 Shelby used the C6ME block with the A scratch on the rear.
        -Keith
« Reply #4 on: April 11, 2019, 09:48:00 PM »
does it have a tag under the coil
