Author Topic: Carb spacer/ air cleaner heigth  (Read 4428 times)
Saltshaker
« on: March 23, 2019, 04:07:40 PM »
I switched to a 9” extreme air cleaner with a flat base and 2.25 high filter. Top of the air cleaner hits the engine hood and my choices are to get a 2” filter or change the 1” carb spacer to a1/2” spacer. Current spacer is open and I do have a 1/2” 4 hole spacer...
jon
Re: Carb spacer/ air cleaner heigth
« Reply #1 on: March 23, 2019, 04:33:29 PM »
What engine is it?
I think you should use all of your available height, for sure.   It doesn't like you have a very big filter so I wouldn't want to exchange much of that height for spacer height.
Why not a drop base filter?
jmo,
paulie
« Reply #2 on: March 23, 2019, 04:36:54 PM »
If you have a single Holley and don't mind using a "GM design", an L88 baseplate works wonders.  It is what I use.  I have a 1" spacer and a 14x3.5" filter on the 428 in my '67 Cougar.
« Reply #3 on: March 23, 2019, 04:39:07 PM »
Is your air filter the one with an additional filter in the lid?
Saltshaker
« Reply #4 on: March 23, 2019, 04:47:12 PM »
The car is a replica Cobra. The top of the extreme lid is touching the scoop. I thought I Need some space between the lid and the scoop.
Jon
« Reply #5 on: March 23, 2019, 04:48:54 PM »
Jon
I think you should have some space over the lid, especially if the extreme lid is the one with the filter in the top.  I personally don't think those are the best filter types.   I'll let the cobra guys take over now.  Brent would know.
paulie
wowens
« Reply #6 on: March 23, 2019, 06:38:53 PM »
allstarperformance.com.      search air cleaner
Woody
Saltshaker
« Reply #7 on: March 23, 2019, 06:43:08 PM »
Thanks but 9” is the max dia of the air cleaner...it sits up un the scoop of the hood. I was trying to find out if I would be better off getting a shorter spacer or a shorter air filter
Jon
« Reply #8 on: March 23, 2019, 08:27:40 PM »
Put the 1/2 inch spacer on it.
I have run those x-stream lids and they did better than the internet said they would....
Saltshaker
« Reply #9 on: March 23, 2019, 08:32:42 PM »
Barry,
Thnx
Jon
Saltshaker
« Reply #10 on: March 24, 2019, 07:20:02 AM »
Will it make a difference if it is a open or 4 hole spacer? Also, will the carb need to be rejected?
« Reply #11 on: March 24, 2019, 07:47:22 AM »
I doubt it will require a rejet.
If you are happy with what you have now, I would run the same style spacer but 1/2 inch.  Hard to tell without testing.
