Author Topic: Need help locating rings....  (Read 3309 times)
64PI
« on: March 21, 2019, 06:35:07 PM »
I have a set of JE super stock legal 390 pistons. I bought them used and I am trying to get a set of rings for them.
-The top ring is a Dykes style ring that measures. .062" (1/16").
-The second is a low tension conventional style ring that measures. .077"... So 5/64" or 2mm?
-Oil ring is a standard 3/16"
-Bore is 4.090"
I would like to stay with the Dykes style low tension ring combo.
Any help is appreciated!
Fred
« Last Edit: March 22, 2019, 05:35:53 AM by 64PI »
wayne
Re: Need help locating rings....
« Reply #1 on: March 21, 2019, 10:46:23 PM »
Hastings rings will help you out
« Reply #2 on: March 22, 2019, 05:39:55 AM »
Call Keith at Total Seal.  You will need to give him all dimensions including the depths so he can fix you up.  You may be able to run a spacer and some thinner rings as well.
64PI
« Reply #3 on: March 23, 2019, 02:53:28 AM »
Total seal is going to help me out. Thanks guys.
