Author Topic: jayb adapter cover  (Read 10232 times)
gregaba
Re: jayb adapter cover
« Reply #15 on: January 23, 2019, 06:21:39 PM »
yeah
That is why I ordered extra. I have a 18 speed drill press and thought I would use the lowest speed and drill just a little bit on each hole going back and forth to keep down the heat.
I don't know how it will work out but hope for the best.
If I have to I will order more lexan until I figure it out.
Greg
gregaba
Re: jayb adapter cover First try
« Reply #16 on: January 31, 2019, 03:49:36 PM »
Hi
Well I have the first one made. I was not trying to make this perfect but just wanted to see how the jig saw would cut and to learn how to drill the holes without melting the Lexan.
The saw blades and drill bits  I bought for the Lexan worked perfect. I decided to cut it real fast like I would metal and it cut like butter.
I did the same with the drill bit to see if it would crack or melt and no problems.
It took me about 30 minutes to saw it out and drill the holes.
Now for the fun-getting the paper off.
This was a real learning experience for me. The first side came off glue and paper after soaking it with dish soap and warm water for about 15 minutes.
The second side was the side from hell. It took me 2 hours to get the stuff off. I followed the directions and soaked it no luck.
The directions said to use goo gone and it would take off the glue.
After letting it soak for about 1 1/2 hour and using a thin plastic card to scrape it off it looked like I hadn't done anything.
I remembered I had a steam cleaner to clean my vinyl records. I was getting it ready and dried the plate off real good getting ready to steam it. When cleaning it I used my fingernail to get a big piece of glue off and the whole thing pealed off.
I guess the secret to use goo gone is to let it soak in, dry it good, and peel.
I also just marked the wholes with a pencil so they are a hair off. On my next try I will get some soft clamps and clamp jayb's adapter cover to it and use that as a guide so my holes will line up.
I think anybody can do this and if you buy the bits and blade's made for Lexan it is easy.
I also rounded the corners with my belt sander as the jig saw didn't want to follow the tight curves very good.
Here are some pictures.
Greg
« Reply #17 on: January 31, 2019, 04:35:14 PM »
The trick to removing the paper is to use a heat shrink gun.  It will come off in a complete sheet if you do it right.  Simple, fast.  Done.  Joe-JDC
gregaba
« Reply #18 on: January 31, 2019, 04:38:24 PM »
Thanks Joe
I have a couple of those guns and will give it a try on my next plate.
I will do number 2 plate tomorrow or the next day and will give your method a try.
Greg
wowens
« Reply #19 on: January 31, 2019, 05:08:28 PM »
There's a big hole in you adapter, I can see right through it !
Slick
Woody
gregaba
« Reply #20 on: January 31, 2019, 05:17:27 PM »
That's so I can change the oil from the top.
Greg
gregaba
Re: jayb adapter cover-Finished
« Reply #21 on: February 02, 2019, 04:55:44 PM »
Made the second plate this evening. I have everything done and with using jayb's plate as a template got the holes drills just right.
The hole you have to watch real close is the top front one on the plate, there is not much clearance on it but if you are careful no problem.
Here is a picture with it mounted and the screws installed.
I was going to make one for the timing cover but I don't know if there is 3/8 inch clearance between the CVR water pump and timing cover or not.
It looks like in the photo's I have seen on the forum that it is real close to the cover.
Greg
62Falcon390
« Reply #22 on: February 04, 2019, 06:54:22 PM »
thats really cool..
gregaba
« Reply #23 on: February 04, 2019, 06:56:12 PM »
Thank You.
Greg
gregaba
« Reply #24 on: March 16, 2019, 06:01:55 PM »
I did a mock up of the setup after I cut the intake to fit jayb's adapter.
So far I am real happy with the way It is turning out.
I still might grind the ends of the intake to match the adapter.
Greg
gregaba
« Reply #25 on: March 16, 2019, 06:03:42 PM »
Two more pictures.
Greg
