Author Topic: Piston to deck clearance  (Read 10952 times)
gt350hr
Re: Piston to deck clearance
« Reply #15 on: January 23, 2019, 11:55:21 AM »
  Depending on which company manufactures the pistons , the ring land area will be undercut from .032-.040 under the actual bore size of the block to allow for heat expansion. That clearance is what causes "cold rock". Taping up that area  obviously reduces the rock ( to simulate piston expansion when running) and allows for easier checking of piston to deck. Piston temperature is highest ( when running) above the top ring and the under cutting and a 1-2* taper keep the top land from rubbing.
    Checking with the lands taped is a great method to use.
    Randy
