Author Topic: Trick Flow and Ersons?  (Read 8496 times)
Re: Trick Flow and Ersons?
« Reply #15 on: January 05, 2019, 06:27:07 AM »
I installed my TFS heads and Comp Ultra Gold rockers without modification.  I checked the contact of the roller to the valve stem through the entire range of motion and all looked well.  I did end up running a valve cover spacer to get rocker arm clearance, but I'm also running stock chrome Powered By Ford valve covers as well.
Granted, I'm not running a ton of lift, but should I be looking at something else?
What did the pattern look like?
KeiserMustang
« Reply #16 on: January 11, 2019, 04:00:59 PM »
What's a good method to check the pattern?
The engine is back out of the car, I'll check it before I tear it apart.
