Author Topic: Blocking Off Exhaust Crossover  (Read 18851 times)
67428GT500
Re: Blocking Off Exhaust Crossover
« Reply #30 on: December 26, 2018, 06:11:51 PM »
I apologize if I missed any responses.  On the Fel Pro 1246-S3 and 1247-S3 intake sets they have a metal core and the heat crossover is blocked off.
I used the 1246's with the 2.34 port heads on my Shelby.
        -Keith
fairlaniac
« Reply #31 on: September 15, 2024, 08:03:13 PM »
Resurrecting this post. I'm going to install a F427 on a 390 I have lying around and put it in a '78 F150. I've never used an intake with the crossover. Does anyone have a good picture of what they did? I can picture the piece of sheet metal but the butter knife? I'm just throwing parts on hand together for this engine. Trying to see if I can use a Fel-Pro 9781 intake gasket as I have about 10 sets lying around.
http://www.fairlanet.com/images/ramsey_9.jpg
Thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
« Reply #32 on: September 16, 2024, 11:28:46 AM »
Doug, all I do is cut a piece of 18 gauge sheet metal into the shape of the hole in the gasket, and RTV it in place over the exhaust crossover hole in the head.  Never had a problem doing it that way - Jay
fairlaniac
« Reply #33 on: September 17, 2024, 07:34:23 AM »
Thanks Jay! Last night I laid an intake gasket on a head and I see it now. Pretty easily made. I guess you want to make sure that when you install the filler plates and intake that something doesn't slide and stack up.
Doug Bender
1978 F150 2WD 390
rockhouse66
« Reply #34 on: September 17, 2024, 07:38:12 AM »
I happen to have .010" stainless shim stock which works well.
Jim
