Author Topic: Guess the horsepower on a little pepped-up 390....  (Read 69292 times)
Re: Guess the horsepower on a little pepped-up 390....
« Reply #120 on: December 09, 2018, 07:14:24 PM »
Been thumbing through the lobe catalogs, looking for the next iteration.  My goal this time around was to go on the lazy side of things.  The next camshaft will be a little more aggressive and I think it will add quite a bit of horsepower.  This cam has a whopping 93 degrees of overlap, but the overlap was an undesired byproduct of the lazy lobes.
« Reply #121 on: December 09, 2018, 08:50:44 PM »
Any chance of a different intake manifold for the next iteration?  Not dogging the Tunnel Wedge.  I have one, but haven't tried it yet.  Even if you can't get a 2x4 Blue Thunder, maybe a 1x4 intake?  Eddy RPM?  or???
just wondering,
paulie
ec164
« Reply #122 on: December 09, 2018, 09:10:30 PM »
Nice job Brent, sounded nice too, will be interesting to see and hear difference in camshaft change! Captain Blair's experience was mighty close(under by 2 ponies) in the corrected #s, with correct RPM! Look forward to next iteration............Al
You're ahead in a Mercury......all the way
« Reply #123 on: December 09, 2018, 09:45:33 PM »
I suspect a huge part of this endevour was aimed at high rpm testing of the rocker arms.
As such I think the tunnel wedge is probably not the worst  choice, at least in regards to breathing ability. Certainly not limited there.
« Reply #124 on: December 09, 2018, 09:49:18 PM »
Neato!  That's an overperforming 390, for sure.  And most importantly, you verified your theories on FE hydraulic roller valve train control.  I am sure that will pay dividends on many future builds.
paulie
That's what I said.  :)
« Reply #125 on: December 10, 2018, 05:53:11 AM »
just wondering,
paulie
I don't want to change more than one variable at a time.  The goal really isn't to see how much power I can make, or else I would have went with 14:1, more head work, etc.  The goal is to test the hydraulic roller cams at higher rpm.  So far, we're on target and need to change a variable or two and hit it again.
« Reply #126 on: December 10, 2018, 06:15:47 AM »
just wondering,
paulie
Makes sense.
bsprowl
    • Ford FE Information
« Reply #127 on: December 10, 2018, 10:15:11 PM »
My guess of 550 at 7000 (top of page 5) was as close as well.
« Reply #128 on: December 31, 2018, 10:07:40 AM »
Guys, I put this engine up for sale in the vendor classifieds.
Dumpling
« Reply #129 on: December 31, 2018, 10:37:58 AM »
What sort of vacuum would this engine produce for power brakes?
« Reply #130 on: December 31, 2018, 10:59:51 AM »
None.
But that’s what vacuum reserve canisters are for.
Dumpling
« Reply #131 on: December 31, 2018, 11:17:27 AM »
Honestly have never found a good substitute for engine vacuum.  Have put in a hydroboost but still not the same.
Thanks
TJ
« Reply #132 on: December 31, 2018, 01:30:41 PM »
If you want the engine, I wouldn't necessarily let lack of vacuum be a deterrent.  Diesel cars/trucks use either vacuum pumps or hydroboost with great results.
« Reply #133 on: December 31, 2018, 03:31:48 PM »
The mule is sold.
« Reply #134 on: December 31, 2018, 04:36:47 PM »
Well that was fast. Congrats
