Author Topic: Specification sheet for the TRW or Seal Power 2294 428 standard bore pistons  (Read 4113 times)
dozz302
Hello, just wondering if anyone has the spec. sheet for the 2294 pistons standard bore. These have a dome. I think they are TRW or Sealed Power. Thanks eparocz@aol.com
Tommy-T
From my 1983 TRW catalog:
L2294F piston std.
1.65 Comp. Dist.
.125 Dome Height
Compression ratio 12.69 with 69.6 cc
                           12.0 with 74.3 cc     with .015 deck clearance and .035 gasket
If they are decent, a full set, and for sale, I'm interested
gearhead427@verizon.net
dozz302
Thank you for the response. Well I'm putting together a motor and have 2 sets of pistons. Not sure which I will use. I will keep your response and If I do sell I will contact you first. Thanks again.
dozz302
Do you happen to know the thickest head gaskets you can buy that are not the cometics- there very expensive. My CJ heads have 66.2 cc chambers. How much would they have been milled then? Just asking -I'll probally start another post if you don't know. Thanks
Tommy-T
The Felpro 8554PT head gasket comes in at about .050.
That's the thickest non Cometic or SCE head gasket I can think of.
dozz302
Thanks, I'll check them out.
