Author Topic: Front Brake Dust Shields.. Yay or Nay?  (Read 6179 times)
amdscooter
« on: November 05, 2018, 05:15:34 PM »
The stock drivers side caliper on my 67 Fairlane went away and I decided to "upgrade" to a nice set of Wilwoods with drilled and slotted rotors as they are a nice match to my black wheels. Decided to reassemble w/o the dust shield until I could get them cleaned up and repainted. Looking at the setup now, I like the sans shield look.. any harm in leaving them off? This is just a street ride that rarely goes more than a few hundred miles on weekends.
Re: Front Brake Dust Shields.. Yay or Nay?
« Reply #1 on: November 05, 2018, 06:30:57 PM »
I say leave them of
« Reply #2 on: November 05, 2018, 07:45:36 PM »
Leave them off, you won’t be able to see all that money you spent on brakes. Just
my opinion.
« Reply #3 on: November 05, 2018, 07:58:31 PM »
X3.
« Reply #4 on: November 05, 2018, 08:18:35 PM »
I'm surprised factory dust shields would even fit or work on aftermarket calipers, unless you're talking about the rear shields that go behind the rotors. I would probably tend to use them, just to keep that nasty dust from coating everything on the front spindles and suspension.
amdscooter
« Reply #5 on: November 05, 2018, 08:44:34 PM »
^^^ I am talking about the rear shield that goes behind the rotor.
winr1
« Reply #6 on: November 06, 2018, 04:07:58 AM »
I installed'74 F100 disks on my '65 F100
I believe they direct air onto the rotor an such
Ricky.
wowens
« Reply #7 on: November 06, 2018, 06:18:06 AM »
Keep them if you can. Helps protect back side from debris that can damage rotor surface. Wheel helps protect front.
Woody
« Reply #8 on: November 06, 2018, 08:23:45 AM »
Rear shield I agree I use them also. I also thought you were talking about outside shields to keep dust off of rims.
« Reply #9 on: November 06, 2018, 09:39:11 AM »
2X on the rears only.  :)
amdscooter
« Reply #10 on: November 06, 2018, 02:38:56 PM »
^^^ Thx all.. guess I'll be tossing them back on once I get them cleaned up.  ;)
FB
« Reply #11 on: November 07, 2018, 08:40:38 PM »
With my Wilwoods, the factory Hats wouldn't fit. the only problem is brake dust gets all over everything,
Fred
chris401
« Reply #12 on: November 08, 2018, 03:29:20 PM »
Ricky.
X2. Just about all dust shileds that I can think of have a scoop to direct air to the rotor.
