Author Topic: Pressure plate recommendation  (Read 3306 times)
Saltshaker
« on: October 25, 2018, 01:42:56 PM »
My pressure plate with a Hyd slave has become to hard to push. Ram 406 3 finger pressure plate, any suggestions? 2600 lb replica Cobra with 428
Jon
Re: Pressure plate recommendation
« Reply #1 on: October 25, 2018, 02:12:19 PM »
Sure it's not a problem with the master/slave?
If it needs replaced, I'd replace it with either a RAM or a McLeod.
Saltshaker
« Reply #2 on: October 25, 2018, 04:16:58 PM »
I replaced the slave and the pressure is the same. Real issue is I have neuropathy in my left foot and need to ease the pressure. The slave is a 1” from a 60’s Ford PU and the MC is a 7/8
Jon
« Reply #3 on: October 26, 2018, 07:26:01 AM »
I always used a 3/4" master cylinder for my Cobra and customers' Cobras.
If the pressure plate pedal pressure has changed recently, then you may want to look at a problem with the hydraulics or the pressure plate itself.
If you just want a different feel, then you can probably change to a McLeod clutch kit with a diaphragm pressure plate and ditch some pedal pressure.  However, it will take some readjustment of your HTOB because the finger height will be different.
Saltshaker
« Reply #4 on: October 26, 2018, 11:42:51 AM »
Thanks Brent
