Author Topic: valve guide question  (Read 3470 times)
GJCAT427
« on: October 11, 2018, 06:36:08 PM »
In building this new tunnel port project, I`m wanting opinions on using bronze guides in this thing. This is going to be a .600 lift OEM cam and matched valve springs. I used bronze in my 400 shop truck motor many yrs ago with out incident and wondered how you guys address the top end.  Usage is street and strip
Re: valve guide question
« Reply #1 on: October 12, 2018, 12:52:06 PM »
If you run aftermarket stainless, you have to use phosphor-bronze as far as I know.  I have only run stock cast iron guides with stock composition valves.  Anything else get's new bronze stuff with Viton seals.
« Reply #2 on: October 14, 2018, 06:07:54 PM »
You can run new valves with any guide.  Cast iron guides and stainless valves need chromed stems.
However, it will be a benefit to you to switch to a bronze guide for a couple different reasons....
1.  The new guides will be already sized correctly for a modern valve seal.
2.  You can have your machinist cut the step off the heads so that you can use a modern valve spring locator that will locate off the valve guide boss.
3.  You can switch to an 11/32" valve stem at the same time.
If the factory guides are worn, you're either gonna need liners or replace the guides.
If they're not worn, then I would at least have the guides and spring seats cut so you can run a nice Viton valve seal and a positive spring locator/cup.
« Last Edit: October 14, 2018, 06:18:56 PM by blykins »
