Author Topic: Time for rebuild  (Read 4145 times)
69Shakar
Time for rebuild
« on: September 21, 2018, 08:06:47 PM »
I have a 69 Torino with a390gt motor that’s really tired.... would like to stroke it to 445. I’ve found a local builder who has a long history building various racing fe’s something he mentioned that I haven’t seen on here or on the various forums is the breaking of main caps from the extra stroke with this build..do I need to take this into consideration or be worried?? What I’m thinking for my build is hydraulic roller cam, flat top pistons, either trick flow heads or barry’s Felony heads, rpm intake, quick fuel 850 carb, not sure if or which rockers to go with.. I know I have to do end stands for the rocker shafts, not sure about which lifters to use or stay away from. The Torino does have power brakes and steering, wide ratio c6, 3.25 gears and 28 inch tall tires. This car probably won’t see a track... just spirited driving, highway, stoplights,... looking for suggestions and or recommendations as I’m trying not to go crazy on the budget..
chilly460
Re: Time for rebuild
« Reply #1 on: September 21, 2018, 09:45:32 PM »
Bunch of 445s out there and I’ve never heard of them breaking main caps.  I have read of some experiences with main web area cracking at the 600-650hp level with racing duty
There are quite a few builds out there similar to what you’re lookig to do
Performer RPM intake
Pistons to hit 9.5-10:1
Survival/BBM heads with light bowl blend or TFS
Hydraulic roller in the 230-235* area .575-.600 Light ballpark should give all around performance and still work with power brakes if you’re careful with overlap
« Reply #2 on: September 21, 2018, 11:23:39 PM »
I wonder why your engine builder is under the impression that the main caps could crack?  Never seen it, in any of my stroker builds.
« Reply #3 on: September 22, 2018, 06:58:52 AM »
Never seen it, or even heard of it, on an FE.
I wouldn’t worry about it and I would actually be leery of how much “racing FE” experience that he has.  Cracked main caps is typically a Chevy problem.
« Reply #4 on: September 22, 2018, 09:08:50 AM »
Only time I ever saw split main caps on an FE was the earliest Genesis blocks.  They had a ductile iron cap with a threaded "pull hole" that was deep into the cap material - a natural stress riser.  Had a couple engines come in after racing service that had caps that came off in two pieces even though they were running fine.  Subsequent blocks had steel caps and bosses for the pull hole & problems went away.
« Reply #5 on: September 22, 2018, 10:40:57 AM »
Perhaps he meant (or said) main bearing cam tunnel cracks...or he is a Chevy guy!
69Shakar
« Reply #6 on: September 22, 2018, 12:11:44 PM »
The reason for breaking main caps might lie in the fact the drag racers he built the engines for are winding them up to 7500.... with 4-5 grand launches.... I’m thinking 5.5-6k for max  rpm capability. When looking at the 70cc trick flow heads  with flat top pistons puts compression at 11-1or so which I assume is to much for 3600 lb car I have no problem with running premium fuel
« Reply #7 on: September 22, 2018, 05:09:13 PM »
7500 RPM isn't going to break those main caps.  The block will go before the caps do.  Cam and compression have to be selected together.  11:1 will be fine with pump fuel, if you have the right cam in the engine.  Do you have a horsepower goal?  That will help with cam and compression selection, but bear in mind that the more HP you want, the less friendly the engine will be at lower engine speeds.
falcongeorge
« Reply #8 on: September 22, 2018, 05:18:57 PM »
That’s my guess, engine builder said main webs, the poster heard main caps.
69Shakar
« Reply #9 on: September 22, 2018, 08:54:16 PM »
I don’t really have a horsepower goal.... I would love to tell someone the engine puts out 550 horse& torque at the rear wheel after showing them up.....am I going to be disappointed if it only does 525 not really... it will still be the most power under the hood of a car that I’ve owned. I realize I will have to  compromise on getting greedy with the power so I have enough vacuum for the brakes to work as they should. I’m trying to get the most bang for the buck without breaking the bank.
fryedaddy
« Reply #10 on: September 23, 2018, 12:27:38 AM »
i think its a bb mopar problem.i have a bracket buddy rebuilding a 440 right now and he decided not to stroke it because of this
chilly460
« Reply #11 on: September 23, 2018, 04:44:38 AM »
550rwhp = ~650hp at the crank, tall order with a 445 retaining power brakes.
« Reply #12 on: September 23, 2018, 06:29:50 AM »
Done several 500 HP 445s the will just tickle 10-11 on vacuum - - just enough for the brakes.
falcongeorge
« Reply #13 on: September 23, 2018, 11:08:24 AM »
built tons of bbm’s never cracked a main cap. More problems with rod big ends, but you really gotta be winging the sh*t out of them. Bbm bottom ends are very robust in my experience.
« Reply #14 on: September 23, 2018, 01:16:05 PM »
My buddy that owns the dyno I use is hardcore Mopar.....he puts aluminum main caps on all his high-end BBM engines because of cracked main caps.  The aluminum caps absorb some of the bad harmonics.
falcongeorge
« Reply #15 on: September 23, 2018, 02:14:53 PM »
All the mopars I built were iron heads, 500-575 hp range (Same power levels we are talking about here, anything will break if you push beyond its intended envelope) stock stroke, not only did I never crack a cap, I never saw any evidence of brinneling at the cap/main web interface, which I have seen on other makes at similar power/rpm levels. I HAVE had some experience with rb rods pinching in at the parting lines at the upper end of the engines I was building. As far as that goes, I have used aluminum rods to absorb the harmonics that otherwise eventually end up in the main webs, but I wasn’t doing that in B.B. mopars, and it was at much higher power levels than we are discussing here.
Clearly, I am rocking the Ford blue boat here, I’ll shut up now, back to your regularly scheduled programming.
« Last Edit: September 23, 2018, 02:23:32 PM by falcongeorge »
fryedaddy
« Reply #16 on: September 23, 2018, 06:30:33 PM »
thanks for the help Brent.thats what my buddy was concerned with -too much hp with the long stroke crank.worried about his main caps, beating on them too much
« Last Edit: September 23, 2018, 07:59:00 PM by fryedaddy »
69Shakar
« Reply #17 on: September 23, 2018, 09:45:06 PM »
I forget that when I’m looking at the various dyno charts for 390’s and 445 builds that the ratings are at the flywheel.... with that being said why isn’t there a bigger difference in power and torque between the two especially with some of the fine flowing heads being offered now.
« Reply #18 on: September 24, 2018, 05:59:08 AM »
First, the difference in power will be dramatic with a 445.  However, with your combo, I think HP goals and examples are not the right indicator.  Build to the use, and just wait and see, it'll feel like a monster.  I think if you dig around, you will find the torque numbers between these 390s and the 445s are night and day.   Look at those and look at average torque.  That being said, you can build a heck of a 390 to replace your tired one, but 28 inch tall tires and 3.25s will be happier with a 445
Second, I have never seen an FE main cap break, and I have certainly read and seen pictures of main saddles breaking, but have never had one come through here.  Especially at the power level and use you are talking, I wouldn't think twice, even with stock main bolts.
I would build a hyd roller 445 for a 5700-5800 rpm peak, TFS heads look good for that with a small fast port that flows a lot of air, although Barry's heads will work great too, do a little professional rubbing on an RPM, and carefully assemble a zero deck shortblock at the right compression to match the cam choice.  It'll feel like a monster compared to your current engine.
69Shakar
« Reply #19 on: September 24, 2018, 10:47:47 AM »
Shortly after getting car had to rebuild rear end at that point had never drove the car at highway speed... so I kept the stock ratio but added limited slip.. it was open before.. found out on the highway with stock tires rpm was 3100 with the tire change it dropped it to 2700 and the car felt better...as I have been working on the car it is being based around the goal of a monster engine under the hood..and now getting sticker shock now that I’m trying to put together everything for the build.. 5 yrs ago when I had the on a dyno we were able to tune it to 290 hp and 385 tq.
69Shakar
« Reply #20 on: September 25, 2018, 11:47:28 AM »
Other than port matching what rubbing would you recommend?? also what is considered to be streetable manners?  I’ve heard the term but not sure of meaning.. i understand that with stroking and larger cam it will idle alittle higher than stock but how much is unsuitable for low speed manners?
