Author Topic: Holley carb questions on the 9510 AC/AD...9510AH and 650 Holley.?  (Read 2751 times)
427LX
« on: September 06, 2018, 08:15:35 PM »
Looking through my 1969 Ford Muscle Parts catalog  they list the 9510 AC/AD carbs as 652 CFM with a 1 5/16 and 1 3/8 sized venturi and 1 11/16 throttle bores. Also the 9510AH as 715 CFM using the same sized venturi and 1 11/16 throttle bores.
Is it the different type boosters altering the flow rate with all else being the same?
And as a side note Holley listed the 650 CFM 4150 series carbs as using smaller 1 1/4 and 1 5/16  sized venturi using same large 1 11/16 throttle bores.
So would the typical Holley 650 carb give same performance as the 9510 AC/AD 652 carbs?
And where does the 715 CFM 9510 AH fit in the mix?
gt350hr
Re: Holley carb questions on the 9510 AC/AD...9510AH and 650 Holley.?
« Reply #1 on: September 07, 2018, 11:24:41 AM »
   652's have "straight leg " boosters and 715's have "dog leg" or angled boosters. The booster changes the airflow through the venturi.
