Author Topic: 68 fairlane street Rod project  (Read 31070 times)
Re: 68 fairlane street Rod project
« Reply #15 on: September 20, 2012, 08:22:56 PM »
Happened to me on a Cleveland. The valve broke of
at the grove for the valve lock so almost the whole
valvedropped down in the cylinder.
Was cruising at 60 and it started to sputter
and the tach jumped allover i pressed down the clutch
and turned of ignition opened the hood and heard the
wather runing in the engine Pulled out the dipstick
and understod it was time for a walk home(pre cellphones)
« Reply #16 on: September 21, 2012, 07:46:00 AM »
Usually when you see carnage like that it indicates piston to valve contact, rather than a valve failure.  A typical scenario is the hydraulic lifters pump up or the springs lose control of the valves at high RPM.  The piston in the cylinder hits the valve because it is open too far (lifter is pumped up or the valve is bouncing off the seat), and breaks the head off the valve.  Once the valve head pops off all that carnage happens in about a half a second.  Been there, done that, unfortunately...
bartlett
« Reply #17 on: September 22, 2012, 08:22:18 PM »
just for you guy's .......... ITS alive .......   http://www.youtube.com/watch?v=vHvc0Jxwzqk&feature=youtu.be
« Reply #18 on: September 23, 2012, 04:55:01 AM »
Sounds good!
lovehamr
« Reply #19 on: September 23, 2012, 08:49:52 AM »
Sounds quite healthy! :)
amdscooter
« Reply #20 on: September 23, 2012, 10:12:43 PM »
Very healthy sounding... !!  :D
funsummer
  • Joel R
« Reply #21 on: September 24, 2012, 12:51:24 PM »
Sounds nice.
Car looks great too.
Can i ask what the cam details are roughly?
Joel Reynolds
1965 Galaxie LTD 2 door.
1938 Nash
bartlett
« Reply #22 on: September 26, 2012, 07:45:56 PM »
248/248 duration @.050
.605/.605 lift
110 degree lobe separation
bartlett
« Reply #23 on: October 06, 2012, 11:55:33 AM »
Took the car in for exhaust ... Im getting 2 1/2 inch 14g alum mandrel bent system with magnaflow mufflers.  Will have a x pipe  and flanges to unbolt system if needed.   1g out the door... alot of dough and I feel its alittle inflated $$ wise but these guys do tons of hot rod work and they make it look real pretty ....  :o
bartlett
« Reply #24 on: October 21, 2012, 07:25:34 PM »
Had a great weather day and got to take it out for a good ride ... The wife kept the hammer in check but it ran great ! Had no problem braking the tires loose at anything under 30mph .. has plenty of zip .... a few bugs to tweek but overall its working good ....  ;D ;D ;D
Thanks for all the help ...
« Last Edit: October 21, 2012, 07:28:41 PM by bartlett »
« Reply #25 on: October 22, 2012, 05:25:30 AM »
Got a video of the new exhaust?
amdscooter
« Reply #26 on: October 22, 2012, 01:09:58 PM »
^^^ What he said.. I'd love to hear it as I'm planning roughly the same thing. 2.5" Aluminized with an "H" bar and magnaflows. Your cam has a good deal more lift than the one I am using but I'd still  have a good idea. Car looks terrific BTW.   8)
bartlett
« Reply #27 on: October 22, 2012, 06:39:25 PM »
sheesh now you want video ? ..... :D  Ill work on that .... :-\
bartlett
« Reply #28 on: November 05, 2012, 09:52:40 AM »
I have been working on jetting/carb tuning. It run's 90% right now. I have been having problems getting the choke set correctly. for some reason I cant get the high idle to engage. So Im taking that apart to figure it out. Also jetting up the secondary. I thought it was running real strong at wot untill I turned on the nitrous with the bottle off,so it would just get a fuel shot and WOW it gained like 50hp ! no kidding.  so I am buying some bigger jets today... and it has a little lean just off idle .. need to get the pump adjusted correctly ect ....
  Also need to pull the valve covers off when hot and adjust the rockers. There set at 20 cold and I'm sure hot there 26 or so.. thats to much .... Im going to set them at 15 hot.
bartlett
« Reply #29 on: May 23, 2013, 05:49:50 PM »
A lot of work this winter but I rolled the car out to day and put some miles on it ! Ran great ! Here is a little walk around for ya !
http://www.youtube.com/watch?v=R6d6QsOl-Zc&feature=youtu.be
