Author Topic: Use comp lifters on Comp Cam or other lifters ?? .. also, ring wear ...  (Read 2642 times)
winr1
Use comp hyd. lifters on Comp Cam or other lifters ??
Any having problems with Comp lifters ??
I have 2 unused sets of Ford factory hyd.  lifters
Used 390, 1st an 2nd rings mike .001 smaller than tiny lip on outside edges
Are the rings worn or can the rings on the outside edge build up a lip ??
Ricky.
