Author Topic: 390 gas mileage  (Read 8878 times)
chris401
Re: 390 gas mileage
« Reply #15 on: September 04, 2018, 01:13:39 PM »
I installed a hei distributor in my 390 with new plugs and wires a couple of months ago. The first thing I noticed was my mileage went from 8 to 11. I was surprised but happy. This was driving in town. Now I am back down to 8-9. What is different. I can not get any better than 8-9 now no matter what I do. How was it up to 11 for a few tanks right after all the new stuff?
If all else checks out, check the tension on your parking brake cable. You could have a slight drag from a rusty cable. If both back seem the same look at the lever and primary cable.
Pentroof
Re: 390 gas mileage
« Reply #16 on: September 04, 2018, 02:09:09 PM »
I installed a hei distributor in my 390....
Someone mentioned it could be retarded. I agree. Putting an HEI distributor on a Ford is retarded. ;D
Jim
Katz427
Re: 390 gas mileage
« Reply #17 on: September 04, 2018, 03:53:08 PM »
After reading some comments, I wonder if any one will believe my old 63 Ford 390 P code would net me 16- 17 mpg running the pike between Syracuse and Hartford, and Boston. That is with 3.50 gears and a 3 speed stick.  Gas was a whole lot better back in the late 60's, early 70's, before the gas crunch.
chris401
Re: 390 gas mileage
« Reply #18 on: September 04, 2018, 05:32:10 PM »
I believe it. Although HP cost fuel these old engines do not have to be undependable gas hogs to run a car up the road.
