Author Topic: Holley C9AF Puking Fuel From Vent Tube  (Read 8544 times)
urchinhead
Re: Holley C9AF Puking Fuel From Vent Tube
« Reply #15 on: August 08, 2018, 06:40:36 PM »
I swapped in an AC fuel pump that was most likely original to my Galaxie, but it would not build pressure. My next step was stealing a Carter M4008 from the Galaxie motor.
I had the exact same problem - it ran for about 30 seconds and then a fountain of gasoline burst from the secondary vent tube. Then the battery died when I went to crank the motor again and read pressure.
The Carter website lists this pump as 8.0 psi "Maximum Pressure." (Edit: I now have a reading - 6.0 PSI, which was fine with the Autolite 4100. I checked the rear float, all was good, checked the needle and seat, reassembled, and then the front vent tube splashed over again. The O rings I have on hand are nitrile, so I might need different ones. At this point, I think I might need to fully disassemble and swap needles, unless I can get o rings separately. )
My vintage HP Books Holley book arrived via USPS today, so hopefully I will figure something out. Thanks for all the help so far!
« Last Edit: August 09, 2018, 06:34:42 PM by urchinhead »
1964 Galaxie 500 Convertible, drivetrain on stand
1970 F100 Custom, 428 - body work and paint in progress
