Author Topic: First drive with the updated 390, comparison to "old" 390  (Read 12334 times)
chilly460
« on: July 20, 2018, 02:34:08 PM »
To recap, 390 in my Merc needed to be cleaned up as years of leaks/spills/etc had it looking pretty ratty.  Stumbled on a deal for BBMs and a hydraulic roller that matched my needs so decided to update the motor while I was at it.
Old combo:
Holley 750DP
Performer RPM (untouched)
270H (224/224 .519/.519 110LA in at 102ICA)
1 3/4" Tri Ys
9.1:1 CR
Edelbrocks with bowl and port entry cleanup and good valve job
Engine ran well, plenty of lowend, did 300rwhp with good AFR and 37* timing.  Ran "OK" but honestly for the parts involved, never felt it was that strong.  I thought maybe there was an issue with the combo, but Barry tested basically this same exact combo and made ~365hp on his dyno which jives pretty well with what mine made in the car so figured there wasn't much more to squeeze out of the combo with tuning or easy parts changes.
New Combo:
Holley 750dp
Performer RPM (plenum entry rolled, port matched, bullnosed the plenum partition)
Survival hydraulic roller 224/230 .563/.563 110LSA 104ICA
1 3/4" Tri Ys
9.2:1 CR
BBMs with 2.09/1.65 and light seat blend
Finally got it in the car and ran it last night.  Obviously the cam is similar, but audibly and driving it gently around town, I basically can't tell a difference.  It may be a bit crisper down low at part throttle which is impressive as the car always had tons of lowend.  Also the valvetrain is quieter, can't say for certain this is cam/lifters as I spent more time setting valve geometry, but it's definitely quieter.
Punch it from a dead stop, better response, not exponentially but it now has traction problems whereas before it would dead hook.  Midrange, honestly, feels about the same.  4000rpm and up, definitely pulls harder and seems to easily pull to 6000.  Previously it would flatten over 4500, and sort of labor to 5400 or so.  It's not a wholesale change, but just pulls cleaner up top now.
Here's the interesting point, I had both sets of heads flowed on the same bench.  I'm apprehensive to do this because the numbers are low compared to full database of what I have for similar heads and guys are going to just look at the numbers....all I care about is the difference between the two ON THIS BENCH.  It's a Superflow 600 bench, but both heads I had done were down ~15-20cfm in the .400-.600 range compared to other records.  The BBMs were done by Brent, my Edelbrocks were done by a very competent builder in PA and this wasn't extensive work on either, and plenty of comparisons for each head so I'm confident that this is just a case of that particular bench being conservative.
My  BBM Cyl1  2.09
71   58
148   105
204   141
240   170
258   189
277   208
291   216
AVE 212.7   171.5
My Ebrocks
79   69
148   114
180   155
218   185
248   206
255   211
257   217
197.9   165.3
The Edelbrocks are more extensively ported than the BBMs.
Should be interesting to get it on the chassis dyno and see how the curves compare, I'm guessing about the same until 4000rpm, then the BBM combo maybe 30hp stronger at peak and carrying much better past peak.   Need to get it to the track in the Fall and see how it does, hoping low 13s but not sure I'd be confident it will get there.
« Last Edit: July 20, 2018, 02:41:37 PM by chilly460 »
Re: First drive with the updated 390, comparison to "old" 390
« Reply #1 on: July 21, 2018, 09:09:03 AM »
Nice work Chris.
Certainly a better build and well suited for use.  You added intake air flow, head airflow, more lift, more exhaust duration, and more overlap, and rolled the cam back a little with a little more seat to seat duration.  I would expect that you will gain along the entire curve, especially mid to upper end, and the car should be a little faster because of that.
CaptCobrajet
« Reply #2 on: July 22, 2018, 05:45:25 AM »
With a cam like that....... streetable 220s/230s, and .563 lift, for the sake of comparison....... Figure at least .020 less lift for deflection.  Throw out the flow figures past .500, because a fairly "pointed" lobe in that range will have very little duration that will have the valve over .500 lift.  With all that said, your average intake flow is 9 cfm better, and your average exhaust is 13 cfm worse.  I would rather have the intake flow than the exhaust, but there won't be much difference in those heads, with the combo you have.  You won't get the best from BBM heads with a 2.09 intake valve.  The bowl and throat are really too big for anything less than a 2.200 valve in my opinion.  I think in a combo with a much larger cam, you would start to see the BBM stretch it out over the Edelbrock based on the info you supplied.  You certainly didn't hurt yourself on the head swap.  I think you will definitely pick up power and ET, but most of the gain is in the camshaft swap.
Blair Patrick
« Reply #3 on: July 22, 2018, 06:30:16 AM »
Chris, the average exhaust flow on the BBM heads is actually 155.2 cfm.
I'm looking forward to seeing what it does on the dyno.  Try and use the same dyno as last time to eliminate any variables.
I will agree with Blair here....I think the hydraulic roller camshaft will be responsible for a good bit of the power bump.  I know that the cam is one of Barry's, but I recently ground a hydraulic roller for a forum member to replace a 294S.  With less duration and similar lift, it made almost 30 hp more with no other changes.  I would expect similar results here, especially with the extra exhaust duration.
I will also say that I think Barry's lower duration cams use a little more aggressive lobes than what I use, which means that the .200" duration will be relatively higher and the advertised durations will be relatively lower.  The higher .200" duration will actually hold the valve open longer, and depending on the lobe shape itself, may snap it open, hold it open, then snap it shut.  You will see some lift loss due to pushrod deflection and valvetrain geometry, but I think the overall lift at the valve will be significant.  You may also see a power increase because of a DCR increase.
The bowl and throat on a BBM are "by the rule" larger than what's optimal for a 2.090" valve, but I have used smaller intake valves several times when the bore size is fairly small.   I know that you bought these second-hand and I can't remember the specs for the engine that they were originally intended for, so that may have been a deciding factor.   You did the right thing and had both sets of heads flowed on the same bench.   I particularly like the flow bump from .300-.500" lift.  A 22-24 cfm bump there is a tremendous help.
Let us know what the dyno says.
« Last Edit: July 22, 2018, 06:34:34 AM by blykins »
chilly460
« Reply #4 on: July 23, 2018, 06:52:13 AM »
Thanks all for the information, good stuff to chew on.  I understood going in that this was an incremental step at best, as I said I got a nice deal on the BBM/Cam and this was a "while your at it" deal to upgrade a bit while I had the engine out for some cleanup.  I believe the heads/cam were spec'd for an "interim" 390 while the guy was building a 445/462 but the details are foggy.
The BBMs are scheduled to go on the 462 I'm gathering parts for, so there are longer range plans that will include getting the heads opened up for the 2.20".  I've been reading a bit about throat sizes, pinch points, minimum CSA and the like just trying to get educated, my guess is that it's not as crucial on a mild 390 like this but on a 6000rpm 462 it will matter.  I was hoping the better chamber in the BBMs would help a bit too.  Also used this as an opportunity to learn how to set pushrod length, degree a cam, port match (rather than gasket match), use a dial bore gauge before I do these things on the 462.  I've slapped together parts before but wanted to get a wee bit more into "building".
Brent, I can hit the same chassis dyno to get somewhat of a back to back comparison.  He's usually fairly backed up but I'll see when I can get on the rollers.
« Reply #5 on: July 23, 2018, 08:29:11 AM »
I'm gonna place a bet that it runs better than the "butt-o-meter" is telling you....
chilly460
« Reply #6 on: July 23, 2018, 12:17:54 PM »
Well we will see, dyno appt setup for Aug 7th.
« Reply #7 on: July 23, 2018, 01:54:10 PM »
 8)
« Reply #8 on: July 23, 2018, 02:40:15 PM »
Kinda hard to tell on the street when the power is higher rpm.
Least with my car, if I get real serious about it, traction makes it not matter so much.
chilly460
« Reply #9 on: July 24, 2018, 12:27:24 PM »
For research purposes only  :)
Needs more go juice
https://youtu.be/Fop57nAYa_4
« Reply #10 on: July 24, 2018, 12:43:38 PM »
Now what has that poor seat ever done to you?
chilly460
« Reply #11 on: July 24, 2018, 01:35:32 PM »
LOL, couldn't get the phone mounted to the quarter window without blocking view of the tach or oil pressure gauge, without putting the seat forward.
« Reply #12 on: July 24, 2018, 03:50:20 PM »
Shoot, sounds like it's running pretty hard to me! From the video, seems the same as our warmed over 390 Mustang, but you're doing it in a Galaxie.
« Reply #13 on: July 24, 2018, 03:59:50 PM »
I use 14 year olds as cameramen.  Works great and is easier on the seats :P
https://www.youtube.com/watch?v=v13_72XREP0&feature=youtu.be
« Reply #14 on: July 24, 2018, 08:29:41 PM »
Sounds great
