Author Topic: Goofing off with some CJ heads...  (Read 22337 times)
Re: Goofing off with some CJ heads...
« Reply #45 on: November 08, 2018, 07:45:38 PM »
Intake port volume is 162.2.
Increase of 7cc.
falcongeorge
« Reply #46 on: November 09, 2018, 11:33:34 AM »
I honestly don't know much at all about 4500's, kinda outside my realm of interest.
You would like them.
You would like them a lot... 8)
I have used 2 circuit dominators on aggressive street/strip big blocks a few times, the ifr's generally need to be reduced, and if the carb you use doesn't have a primary side power valve, you will want to add one, once you have done that, they work very well indeed..
« Reply #47 on: November 10, 2018, 07:47:46 AM »
Heads are assembled and set up for my 390 dyno mule.
Very pleased with how they have turned out.  280-290 cfm from a 2.080" intake valve sitting in a 162cc port isn't shabby.
Assembled with Comp conical valve springs and PAC titanium retainers.
And a shot of the mule......factory crankshaft, with Molnar rods and Racetec dome pistons.
« Reply #48 on: November 10, 2018, 08:37:05 AM »
Night and day difference between those heads and the ones I boxed up and sent out this summer!  Nice work, they should do well, especially with your ability to keep the port volume under control
I cannot wait to hear the mule at full song!
« Reply #49 on: November 12, 2018, 01:02:46 PM »
Just curious, what's the difference between the intake and exhaust valve seals?
« Reply #50 on: November 12, 2018, 01:06:30 PM »
My "leftover pile" consisted of some 5/16" stem valves and some 7mm stem valves.  A regular Viton seal for a 5/16" stem .530" guide is readily available, but I had to scrounge up some Viton seals for the 7mm stems.  The 7mm exhaust valves got the orange seals.
« Reply #51 on: November 12, 2018, 02:24:43 PM »
Broncos fan is my guess....
« Reply #52 on: November 12, 2018, 10:34:07 PM »
And I was guessing there was something special about the orange seals. Sometimes a round peg is just a round peg..lol
Ross, not gonna lie, I'd be disappointed if he was a Broncos fan  ;D
