Author Topic: Planning out a new exhaust system  (Read 9469 times)
427LX
Re: Planning out a new exhaust system
« Reply #15 on: June 19, 2018, 11:01:47 AM »
On my exhaust setup I came up with a merge chamber between the 3 inch pipes that lets me choose between an X flow or
fully separate flow.
What I noticed is when I want the nice rumpity throaty sound I swap in the divider plate which has little if any crossover flow.
Seems to give a bit quicker throttle response.
Switching the plate to a flat plate gives the full crossover X-flow and smoothes out the sound and seems to give a better pull thru the RPM range.
Best of both worlds when you can change it around!
Pontiac787
« Reply #16 on: June 20, 2018, 02:41:51 PM »
Does anyone know if Flowmaster will sell the pipes to their kits separately?  They have a 2.5" stainless kit with an H pipe that is exactly what I'm looking for but I don't want the mufflers.  I reached out to the company but haven't heard back yet.
JamesonRacing
« Reply #17 on: June 20, 2018, 04:08:59 PM »
Wanted the back part of the Flowmaster kit for Fairlanes since the mid-section wouldn't fit my convertible chassis.  I talked to a sales rep and he said they can't do partials unless (wink wink) I was buying repair parts for a system that was damaged in an accident.  Ended up selling me the tailpipes and hangers separately.  That was several years ago, so they may have a different policy now.  The easier option is to buy the entire kit and sell the mufflers on ebay.  You'll lose a little on the mufflers, but you may be saving over the individual piece part price.
Pontiac787
« Reply #18 on: June 20, 2018, 04:18:39 PM »
That's what I was thinking.  Especially if going through a seller like Performance Peddler.
« Reply #19 on: June 21, 2018, 06:35:20 AM »
That is certainly an option, but another option is buying 5.0 Mustang tailpipes, mandrel bent, and then cut the exit to fit.  I haven't don it, but friends have.  Use the mufflers you want and then buy a couple J-shaped mandrel bent pieces to make your intermediate pipes.
I have found, with a big cut off saw and a little welding, you can make a much nicer setup than a "fits-all" exhaust and it's cheaper.
